How to rewire...
How to rewire...
Postby meby » Sun Apr 25, 2010 3:05 pm
How do I rewire a air compressor from 240v to 120v? The compressor is a 4 gallon emglo.
Thanks,
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: How to rewire...
Postby BobS » Sun Apr 25, 2010 4:23 pm
If it is capable of being wired for either voltage the motor will have a removable plate cover and will have a diagram that tells you what number leads to connect together for either voltage.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby meby » Mon Apr 26, 2010 12:06 pm
here is my dilemma. it came with a 120v plug on it, but the motor will not turn under pressure. If I disconnect the tank and let it freewheel, it turns at near normal speeds. I can stop it just by putting a finger over the outlet. My first thought was it was wired for 240v. Ideas? Oh, and it does not have a diagram that I can find.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby 1STGENFARMBOY » Mon Apr 26, 2010 2:37 pm
if you can give me all the info off the motor nameplate i can get a diagram, if its a duel voltage
it will say 115/230 volt and have two amp ratings on the motor name tag.
Darwin
Postby meby » Thu Apr 29, 2010 6:38 pm
I will check once I get back home.
Right now I am at the hospital. Our baby girl was born several hours ago. :D
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby Richie O » Thu Apr 29, 2010 6:47 pm
Someone forgot to use this :safe:
Congats. :D
Postby PToombs » Thu Apr 29, 2010 6:48 pm
Congratulations Matt!
Postby meby » Fri Apr 30, 2010 7:15 am
Thanks fellas. :D
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby 1STGENFARMBOY » Fri Apr 30, 2010 7:23 am
congrats!! what ya gona name her.....Cetain?.....Boost?.....Turbo?......Dieselena?..... just to name a few. :lol:
Postby meby » Sat May 01, 2010 5:39 am
1STGENFARMBOY wrote:congrats!! what ya gona name her.....Cetain?.....Boost?.....Turbo?......Dieselena?..... just to name a few. :lol:
LOL. :lol: Nope. Her name is Lauren Elizabeth.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Sun May 02, 2010 6:36 am
An "LE" model! :lol:
Postby 1STGENFARMBOY » Sun May 02, 2010 11:32 am
Ha i knew there would be some sort of conection with our trucks. :)
Dar
Postby dpuckett » Sun May 02, 2010 2:34 pm
Congratulations, Matt.
Return to Shop
