349/827 on #2 Only
349/827 on #2 Only
Postby TWorline » Mon May 17, 2010 8:07 pm
Here is a video of my truck making 349/827 on the rollers at the 4 Wheel Jamboree in Lima, Oh. The Water/Meth is not working so this was on #2 only. :mad:
Tim Worline
http://www.CoolerTubz.com/
TWorline
Re: 349/827 on #2 Only
Postby 1STGENFARMBOY » Mon May 17, 2010 8:22 pm
That sounds very good Tim, do you have a P/S intercooler? kinda looks like one in the grill. those are some nice numbers
i would be happy with those. I bet with the W/M workin it would be in the low 400's :shock:
Dar
Postby SNOOT » Mon May 17, 2010 9:07 pm
Looks more like a 2nd gen cooler to me...
Its got way more then 349 who ran it on the rollers you or the dyno owner?
1993 W350
SNOOT
Postby RumbleFish » Tue May 18, 2010 11:51 am
iirc its a cheap ebay riceburner ic. run looks good tim. did your sales do any better after we talked? it was good to shoot the bull with you again.
Postby TWorline » Tue May 18, 2010 3:55 pm
Thanks guys! The dyno operator ran it on the rollers. Jeff is correct, the I/C is a universal ricer that that only cost me around a $100 brand new. It is one of those that will not work in our trucks because it is to cheap. :P As far as the sales go I did ok, and hey it is always good to talk to you as well Jeff.
Tim Worline
TWorline
Postby PToombs » Tue May 18, 2010 4:47 pm
You beat me by 2/ 28. I need to get more air in mine pretty quick! :cry:
Good job! 8)
Postby 921stgen » Tue May 18, 2010 5:12 pm
Congradulations again Tim, glad you found time to change that u-joint. Taking the wife and getting volunteered to cook for the 4wheel parts guys made it a fast weekend.
91 W250 pods, , pull cable, Isspro FP gauge, Isspro boost, pyro, 366 spring, 91 W350, sold-92 W250, 40 hp Injectors, Bully Dog Fuel Pin, Isspro-tach, boots, pyro, AM electric fp gauge, 3200 GS, 5" AEM intake, 4" exhaust 5" stack
921stgen
Postby soggy » Tue May 18, 2010 5:15 pm
Nice numbers, is that the highest it's done?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby TWorline » Tue May 18, 2010 6:17 pm
Yeah it was a quick weekend, it sure was good to see the 1st. Gen crowd again and some new faces as well. That is the highest dyno result with #2 only, 2 years ago I put down 314/910 on a Dyno Dynamics roller at Zanesville, OH. but that was with water/meth. I thought I might have a leak in my system because my boost has been down around 7psi for the last couple of months. It all made sense when I saw a quart of my special mix flow out of the left side by the bumper. I will check it out later this week to see what is going on.
Tim Worline
TWorline
Postby oldcool90 » Thu May 20, 2010 4:28 pm
Look how clean that truck is that should be worth a few hp.If i knew that was going on i would of made the trip over to ohio to talk truck's with ya Tim. :grin:
oldcool90
Postby The_Head » Thu May 20, 2010 7:10 pm
Is this truck a manual or an auto? I think it's a manual (can't see video here).
The_Head
Postby unixcowboy » Fri May 21, 2010 8:38 am
oldcool90 wrote:Look how clean that truck is that should be worth a few hp.If i knew that was going on i would of made the trip over to ohio to talk truck's with ya Tim. :grin:
2nd ...
Been looking for a dyno day close and when I find one I'm a week late :cry: :cry:
Nice run Tim. BTW - I'll be contacting you about a set of Tubz once I get the PS 'cooler set up to install.
Checking thru other installs I think upside down and in front of the A/C will be the way to go, but first I need to pull some pieces and test fit...
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby meby » Fri May 21, 2010 12:19 pm
The_Head wrote:Is this truck a manual or an auto? I think it's a manual (can't see video here).
He has an NV4500 in it. 8)
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby TWorline » Fri May 21, 2010 6:55 pm
Matt is correct, it has a NV4500 in it. From the pictures that I have seen of the ps retrofit upside down and out front seems to look the best from a fabrication standpoint.
Tim Worline
TWorline
Postby SNOOT » Mon May 24, 2010 12:14 pm
Just for reference here is a 355HP run with an auto... Single turbo at the time on #2
http://www.youtube.com/watch?v=Bi21zyQCa9s
1993 W350
SNOOT
Return to Competition
Users browsing this forum: No registered users and 102 guests
