Gauge pod alternative.
Postby meby » Mon May 03, 2010 3:16 pm
Here is an alternative to ill fitting gauge pods or pods that break the bank. I bought a 25 dollar fully enclosed gauge cup from a local auto value store. There is enough room to easily fit three or four gauges on the pillar. I is mounted so that the gauge is facing directly at the driver (can be adjusted to fit you really tall or short guys :lol: ), not like the autometer one that only works for 6' 20'' people. :mrgreen:
This is the view from the driver seat.
This is the view from the outside, pardon the glare of the glass. The wire is barely visible from the inside or outside of the truck. I took some really thick electrical tape and wrapped the wires in it. If you wanted to go to a little more trouble, you could drill a hole in the trim piece to shorten the exposed wire from about 7'' down to 2''.
Be careful though when you drill through the plastic trim piece, it cracks real easy. :(
Oh. and here is a picture of the truck.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Gauge pod alternative.
Postby redneckroot » Sat May 15, 2010 10:26 pm
That was the same thing I thought. I like them because I can move them anyway I want, plus I can add more as needed.
redneckroot
Postby Cummins Jr. » Thu May 20, 2010 11:16 pm
nice man i really like this idea, thank
Cummins Jr.
smoke screw?
Postby bmoeller » Sun Apr 03, 2011 1:55 pm
Made a dash mount out of a $9 bread pan for my KW truck. Has a fuel psi and a fuel temp gauges in it. :)
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby The_Head » Sun Apr 03, 2011 3:31 pm
I like it too.
The_Head
Postby redneckroot » Sun Apr 10, 2011 8:16 pm
The really nice part about the individual pods is you can always add more without making the pillar look like a cobbled mess.
redneckroot
Postby PToombs » Mon Apr 11, 2011 5:42 pm
Until the plastic breaks and they all fall down. :(
Unless you have them screwed into the pillar itself. ;)
Postby redneckroot » Tue Apr 12, 2011 8:27 pm
Mine are screwed right through the plastic into the pillar. Without a screwdriver or hammer they aren't falling off. I really like them because you can also adjust them exactly how you want them. I haven't seen a 1st gen pillar set up that I can say is easy to read. Plus the individual pods makes me feel like it is a more true to its time look, back when everyone had tach's on their trucks and cars on the corner of their dash.
redneckroot
Postby 1stgenblowingsmoke » Sat Aug 27, 2011 3:46 pm
I did the same with mine my interior has changed slightly from the first pic but gauges still mounted the same way.
90 LE 250 reg cab 4x4 5 speed getrag. Fuel screw turned to factory stop, throttle rod mod, 3.5in flow through exhaust, #75 fuel pin rotated, HX-35 waiting to on along with an intercooler.
1stgenblowingsmoke
Return to Cool projects YOU can do
