BIG ASS PULLIN HITCH
Postby pulltilbroke » Fri Jul 16, 2010 4:56 am
Here is what stillsmokin and me have been workin on this week. Jeff designed it and I have done about 90% of the welding on it and it is not finished yet, it will eventually have another bar coming off the center of the truck and tying in to the "Reese" hitch. It will technicly have a removable drawbar.
This was tonights project, I put about 5 hour into this welding it up. Lotso passes. I put about 15 passes on where the 2" bar stock meets the hitch channel because of the deep bevel I put on there. That was done with a 6011 root and 7018 cover passes. On the gussets I put down 6 passes on the out side all done with 7018.
Before Gussets
After gussets
Re: BIG ASS PULLIN HITCH
Postby unixcowboy » Fri Jul 16, 2010 9:12 am
You're going to pull your chassis in half before that baby gives :lol: :lol:
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
unixcowboy
Postby pulltilbroke » Fri Jul 16, 2010 12:46 pm
Jeff said he only wanted to build a hitch once. :D
Postby pulltilbroke » Sat Jul 17, 2010 12:02 am
Should be testing it tomorow in Johnson NE
Postby cedardiesel » Sat Jul 17, 2010 9:27 pm
I'm more amazed at the prestine welding lob that you all did but I don't think it's going anywhere without the truck tho lol By the way gorgeous puller too
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby pulltilbroke » Sun Jul 18, 2010 12:53 am
Didn't break tonite :D , Jeff pulled 2.6 and 2.8 an ended up 3rd and 5th
Postby pulltilbroke » Sun Jul 18, 2010 1:41 am
Postby cougar » Sun Jul 18, 2010 8:42 am
NOW That's what I need for pulling trailers across Alaska!
01 2500 "the work truck".
cougar
Postby stillsmokin » Sun Jul 18, 2010 12:57 pm
I think all the extra thinking on setup is really helping the trucks consistency. FWIW, I ran 2.8 just so my wife and my brother in law could see it run, and make a change or two to test the new setup a little more. So 5th amongst some stout running trucks was surprising. The truck that took 4th put 22 feet on me in the 2.8, it has a woodruff 5.9 and a 13mm P7100. Several SJD sponsored trucks were at the event as well.
A few changes and I'm going to start chipping away at that truck length he has on me. But, i will gladly take that pass of 339', if I'm not mistaken that may be one of the hardest passes ever laid down with a VE truck tied to a sled. It's on
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Postby unixcowboy » Sun Jul 18, 2010 2:25 pm
Keep it up !
Show them a VE can run with the best....
unixcowboy
Postby pulltilbroke » Sun Jul 18, 2010 2:37 pm
Return to Competition
