Axle ratio?
Axle ratio?
Postby 1$Chuck » Thu Jul 15, 2010 12:07 pm
Is there an easy way to tell what axle ratio a 1st gen truck has? Is it stamped somewhere, or is there a way to decipher the VIN number?
1$Chuck
Re: Axle ratio?
Postby Richie O » Thu Jul 15, 2010 1:36 pm
If the tag is still under the hood and its original then its listed there. There also may be a tag on the housing if its not rotted off. Over the years there were only 3 ratios available for the whole series. 89 through 93.
Re: Axle ratio?
Postby meby » Thu Jul 15, 2010 5:11 pm
Or call your dealer. They can tell you what the original one was based on the vin #.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Axle ratio?
Postby 1$Chuck » Mon Jul 19, 2010 5:30 am
Thanks guys. After some wire brushing of old dirt and crap off the differential housing, I found the tag. 4.10 gears with manual transmission..no wonder it seams like I'm driving a tractor.
1$Chuck
Re: Axle ratio?
Postby flyinredneck » Tue Mar 15, 2011 9:13 pm
where was it at on the housing
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: Axle ratio?
Postby PToombs » Wed Mar 16, 2011 5:26 pm
Mine was stamped on the right axle tube just out from the center housing.
Rear side.
Re: Axle ratio?
Postby DieselLam » Wed Jul 13, 2011 3:15 pm
That works if you know your gears are stock. If they might not be then Jack rear end up turn,driveshaft one time while counting how many times your tires turn.
1993 D-250 straight pipe, PDR intake, Pump tweaked. KDP DDP fuel pin.
DieselLam
Re: Axle ratio?
Postby Richie O » Wed Jul 13, 2011 3:45 pm
DieselLam wrote:That works if you know your gears are stock. If they might not be then Jack rear end up turn,driveshaft one time while counting how many times your tires turn.
Kinda. :D Its the other wy around. How many driveshaft turns to 1 tire revolution. You also need to make sure both wheels are up and that both wheels spin the same amount. ( make sure a brake is not dragging the wheel )
Re: Axle ratio?
Postby DieselLam » Thu Jul 14, 2011 3:56 am
Oh yeah thats right , thanks
DieselLam
Re: Axle ratio?
Postby flyinredneck » Thu Jul 14, 2011 9:52 pm
so say the dr turns 4 times and your tires turn 11 you have 4:11 's
flyinredneck
Re: Axle ratio?
Postby Fred_M1010 » Fri Jul 15, 2011 1:59 am
flyinredneck wrote:so say the dr turns 4 times and your tires turn 11 you have 4:11 's
No, it's 4.11:1 and not 4:11.
So 37 turn on the driveshaft gives 9 on the wheel (37/9=4.11)
Or you could just count the turns on the DS while turning the wheel 1 turn.
If it turns 4.11 times, you have 4.11 gears.
But as stated above both wheels must turn the same for this to work.
If you have a limited slip this is no problem, the other wheel will follow if you jack up both of them.
But if you have an open diff you can also do it by jacking up only one wheel.
Then you have to turn it 2 turns instead of 1, to get the proper count on driveshaft turns.
But why not open the diff cover and check the markings on the ring gear,
it's probably time to change the oil anyway ;)
-91.5 W250
Fred_M1010
