if i would run 5x14 injectors and 56mm turbo would egts be ok ? or would it be better to run a 60mm compressor upgrade ? the truck never tows anything above 10k lbs except for a sled what is your opinons ?
thanks spencer
dpuckett wrote:Your stock injectors are good to 300hp or so, with supporting air flow improvements. You may want to just stick with the stock sticks til you can afford to make it a full time toy, at which time, you'll want to upgrae to either a 5spd or built auto.
DP
spencermumma wrote:how would an hx40 do with stock injectors and fuel turned up ?
spencermumma wrote:5sp parts are getting around can a getrag work or is the nv4500 alot better option?
Users browsing this forum: No registered users and 79 guests
