by cougar » Sun Oct 03, 2010 10:21 am
No, I haven't checked the case pressure. How can you check it?
When I tried to install an M&H timing spacer a few months back, my engine suddenly ran like crap from idle up. Took it back off and it was happy again. My guess is the lower tension on the spring allowed some advance at idle. It should not have effected idle, but it did.
I finally got some timing tools and will try to check it tomorrow when it's not raining. At least it will tell me if the previous owner changed the timing and by how much. The pump is in the full retarded position so I can't turn it lower. I don't want to advance it because I think it is as far as it can safely go now. Checking it will tell.
01 2500 "the work truck".
