painting truck
both inside and out
painting truck
Postby sid » Mon Jul 16, 2007 7:23 pm
I just got my 91 ram. it has surface rust on the roof. Not near the windows.
how do I go about taking care of it. since there are a few dent issues on other parts of the truck I figure I would address the most pressing issue. should I use spray cans and etching primer? would that be compatible if I end up paint the whole truck at once sometime into the future?
there is a dent on the right rear quarter panel. A body man said I could buy section and weld it?? the other place for that is on the cab next to the handle. along the door jamb.. i am not making this a show truck but i want it to be resoectable since it is a very low mileage truck!!
sid
Postby jogl » Tue Jul 17, 2007 3:31 am
Sid:
I've just been getting into some body work over the last year myself.
It is one of those things that you have to learn by doing.
As far as painting goes I'm using the "Roll your car" method where you use a roller to paint your vehicle with rust paint. Sounds wacky but it works incredibly well.
Here's a few links in case you haven't seen this before:
http://board.moparts.org/ubbthreads/sho ... ost3493382
http://rollyourcar.com/default.aspx
JP.
92 W250 and lots of others.
jogl
Postby PToombs » Tue Jul 17, 2007 1:51 pm
If you have surface rust and it's above the windshield, you probably don't have a roof left. These trucks hold moisture in a panel up there, and it rusts from the inside out. I hope this isn't your problem, it sucks to find out your new creampuff is a rust bucket. :cry:
Postby BEARKILLER » Thu Jul 19, 2007 4:38 pm
PToombs wrote:If you have surface rust and it's above the windshield, you probably don't have a roof left. These trucks hold moisture in a panel up there, and it rusts from the inside out. I hope this isn't your problem, it sucks to find out your new creampuff is a rust bucket. :cry:
Though bad, it's not the death of the truck.
There are many "custom" approaches to conquering the cab-rust demon.
Fiberglass is an easy solution.
If the rust is bad, and you want a truly custom look, then graft on the top from a hi-rise fiber-glass topper, complete with the aerodynamic angled glass panels.
Modified as such, you can then put risers under the seats to get them up there where you can REALLY SEE, sort of big truck style.
MY TRUCK = 1985 FORD F-350 2wd, 89 1st.Gen.Cummins,Getrag 5-sp,Dana70 3:55
WIFE'S TRUCK = 1991.5 D-250 I/C, Auto
SON'S TRUCK = 1990 W-250 Getrag
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby ekk33 » Thu Jul 19, 2007 4:42 pm
I plan on patching in a new roof, when I get the chance, I allready cut one out at the junkyard. Not sure how it is exactly it is going to work, but I will be sure to take pictures when I do,
1992 W250
Cooler Tubz, PS Intercooler
Pump Mods,3200 Spring,
ekk33
Postby sid » Wed Aug 08, 2007 8:14 pm
where do I get the caulk that is used as a sealer from the factory to go along the roof seam?
Sid
sid
seam /roof caulk
Sid
sid
Postby KTA » Thu Aug 09, 2007 6:42 am
Use 3m automix 8115 panel bonding adhesive.
Postby sid » Thu Aug 09, 2007 6:24 pm
hi since I havent gotten the 3m aouto noding yet can you yrll me the preperation?
sid
Postby sid » Thu Aug 09, 2007 6:25 pm
sid
Postby KTA » Thu Aug 09, 2007 6:26 pm
Wire wheel to bare steel then acetone both surfaces clean.
Postby sid » Thu Aug 09, 2007 6:56 pm
Is it compatible with rustoluem enamel?
sid
Postby sid » Tue Nov 06, 2007 8:29 pm
I just rolled hound and cab top with rustolieum. doesnt look bad. I use white. I need a dodge blue rustoliuem or any dodge color ruastouliem. Anyone see any?
sid
Return to Body
