Spindle nut socket P/N's
Postby jeff77indy » Thu Jun 24, 2010 3:14 pm
I was taking the front hubs off my '92 W350 and found that the spindle nuts are not the same as the '89 I used to have and still have the sockets for those axles. The front on the '92 will need a 7158 will the rear axle nuts require a different socket than the Dana 60 that was in the '89?
Any one have the NAPA P/N's for these?
Thanks
Jeff
U.S. Navy Submarine Service Retired
1992 W350 C&C w/ 9' flatbed, NV5600, Skyjacker 2" lift, Borgeson , Isspro, draw straw, big line kit, piston lp, swiss cheesed air housing.
jeff77indy
Re: Spindle nut socket P/N's
Postby PToombs » Thu Jun 24, 2010 5:41 pm
The rears should be a 2 9/16 inch socket. Napa should have them readily available.
Postby jeff77indy » Thu Jun 24, 2010 5:56 pm
Good, I still have that one, just need to order the 7158 for the front.
Thanks
Jeff
jeff77indy
Postby Moebiusgold » Sun Oct 10, 2010 9:11 pm
Is that an OTC 7158? The description of that says it is for 94 and newer Dodge with a Cummins and a D60...
http://www.tooltopia.com/otc-tools-7158.aspx
92 W350 DRW
Moebiusgold
Postby jeff77indy » Wed Oct 13, 2010 9:40 am
Moebiusgold wrote:Is that an OTC 7158? The description of that says it is for 94 and newer Dodge with a Cummins and a D60...
That's it, bought mine at Auto Zone. They had it on the shelf.
Jeff
jeff77indy
Postby Moebiusgold » Wed Oct 13, 2010 10:52 pm
Thanks Jeff :)
92 W350 DRW
Moebiusgold
Postby Dodgeballs » Sun Feb 08, 2015 4:16 pm
I purchased a 2-9/16" OCT thin wall socket from NAPA. Socket #2438. It will not work. The nut has short flat sections in between each of the 6 flat sections. The socket only has the 6 flat sides. Can anybody point me in the right direction?
1993 W250 clubcab auto 12v all stock 140k, 2006 quadcab longbed 4x4 auto all stock 80k.
Dodgeballs
Postby CumminsPower59 » Mon Feb 09, 2015 3:34 am
Will it physically fit on the nut? If so, it'll work....try it. Really just about any axle nut 2 9/16" socket will work on the rear spindle nuts.
Postby BILTIT » Mon Feb 09, 2015 10:44 am
You can swap out the rear nuts to the same as the front and only have to buy/carry one socket, its a better design too.
http://www.partsmike.com/index.php?crn= ... how_detail
Derek B.
BILTIT
Postby CumminsPower59 » Mon Feb 09, 2015 11:04 am
BILTIT wrote:You can swap out the rear nuts to the same as the front and only have to buy/carry one socket, its a better design too.
That's what I did. Hands down better design, as you aren't relying on a very small metal tab to keep the bearing nut in place.
Postby Dodgeballs » Fri Feb 13, 2015 8:46 pm
CumminsPower59 wrote:Will it physically fit on the nut? If so, it'll work....try it. Really just about any axle nut 2 9/16" socket will work on the rear spindle nuts.
No, it wont fit over the nut. Its Not a standard 6 point nut.
Dodgeballs
