superbeemike wrote:I'm working on the same thing, except I'll be converting to 4x4 after I get it on the road. I'm interested on what your plans are for the 4x conversion. I was planning on grinding off all the rivets and pulling the front cross member and 2wd stuff. I'm not a big fan of splicing frames together. Good luck with it. Mine has been alot of work but fairly simple. Almost like it was made to be there. I will be checking on your progress....
Mike
PToombs wrote:Wow, that's really stripped down. Where the hell do you find time for projects like that? I have a JD "R" that I started to restore 5-6 years ago and is about 2/3 done, then life got in the way. Darn kids, too young to help and too old to sell.
Good luck, should be fun when you're done!
superbeemike wrote:Lugnutz,
Why the RC fuel tank? Is it an extra or are you passing on the saddle tank?
Thanks
MIke
dazedandconfused wrote:Rivets are a piece of cake to get out. 4" angle grinder with cut off wheel and good grinding disc. Cut off the head as close as possible to bracket, lightly grind it. Use a good air chisel and they pop right out the other side. I've done many frame brackets this way. It's fast and clean. I've used a die grinder for the hard to get to ones. I want to find a 2wd crew cab rolling chasis in good shape.
Users browsing this forum: No registered users and 75 guests
