my brakes ar goin dnt know whats goin out tho.
Postby bigbad_Canam » Sat Jan 29, 2011 5:40 pm
bout april did the front brakes. pads, and roders. bout september did the rears. drums, shoes, 1Inch wheel cylinders. well 2day for som reason, my truck isnt really stopin. i re-bled the brakes, took the tires off and checked everything. it all looks new, u know and nothin is wet from the fluid. when im drivin and i hav to stop, she wont stop. the pedal is to the floor, but now if i pump the brakes then hit em, ther fine. not even a minute later i hit the brakes and it does the same thing.
Whats the problem. would it be bad master cylinder...? i dont know
please help.
thanks.
bigbad_Canam
Re: my brakes ar goin dnt know whats goin out tho.
Postby ellis93 » Sat Jan 29, 2011 6:16 pm
If your not seeing fluid anywhere then its very possible that the master is going
Postby PToombs » Sat Jan 29, 2011 6:34 pm
It may also be the ABS valve in the rear if it's still on there. I'd bypass that 1st, it's cheaper to buy the fittings than a master, and it's the most likely culprit.
Postby ellis93 » Sat Jan 29, 2011 6:36 pm
:oops: forgot about that thing.
Postby PToombs » Sat Jan 29, 2011 6:41 pm
I forgot about mine after it was gone about a week. Haven't missed it a bit since. :mrgreen:
Postby rebel horseman » Sun Jan 30, 2011 6:49 pm
Eliminating the rear ABS valve will eliminate the rear wheel ABS function correct?
'93 Ram D350 Club Cab, ETC, G360, 366 spring, fuel screw screwed, star wheel bottomed, smoke screw flush, BHAF, straight pipe, DennyT Stage II pin. 182k miles.
rebel horseman
Postby ellis93 » Sun Jan 30, 2011 6:57 pm
Yep all gone. Mine never worked anyway.
Postby rebel horseman » Sun Jan 30, 2011 7:12 pm
Interesting. Since you're in roughly the same climate area I am, have you had any problems with the rear brakes locking up on you at inconvenient times? How does it do in the rain without ABS?
rebel horseman
Postby ellis93 » Sun Jan 30, 2011 7:31 pm
I've been rid of mine for a few months now. At the same time I turned the drums and swaped over to one ton shoes and wheel cylinders. I've had nothing happen. No skidding or sliding, just a firmer pedel and a quicker stop. Really there is no downside to it. I think that the ABS only works from like 35mph and down anyway. I know for a fact that chevy and ferds early versions do so I would assume ours do as well.
Postby rebel horseman » Sun Jan 30, 2011 7:33 pm
Interesting. I'd love to have a better brake feel in my dually but I don't want to pull a Smokey and the Bandit power slide in traffic either. How hard is the conversion?
rebel horseman
Postby ellis93 » Sun Jan 30, 2011 8:02 pm
All you need to do is buy the fittings to ty the two lines together at the abs unit. You already have the shoes and cylinders. I can't remember the part numbers for the fittings but do a search on here and you should come up with them. If not I'll dig in my Oreilly's receipts for them.
Postby rebel horseman » Mon Jan 31, 2011 6:45 am
I'm pretty sure these are the numbers. If it's dry this weekend I may be doing this mod this weekend.
http://www.1stgen.org/viewtopic.php?f=2 ... lete+parts
rebel horseman
Postby ellis93 » Mon Jan 31, 2011 7:15 am
That's them! I had to order mine. Good luck on the hunt.
Postby rebel horseman » Mon Jan 31, 2011 10:21 am
Posted an update on the replacement parts from my local NAPA store. The WEA numbers are right and the parts are not too expensive. I think the total is going to be just under $12 fro both fittings.
rebel horseman
Postby slow_90firebird » Sat Feb 05, 2011 4:55 pm
my master went out before, i was having to pump it to stop.
Just in case you dont know, there is a trick to changing the master without bleeding the brake lines out:
First fill the new master and bench bleed it in a vise.
Then put it on the truck with the plastic plugs in the sides with screws to stop it from dripping.
Take out the plastic plugs
Have someone get in the truck and slowly push the pedal to the floor, and hold it to the floor.
Quickly attach the lines and snug the flare nuts down tight but not too tight.
Have the person release the brake pedal and it should suck the little air bubbles back up into the resivoir.
good luck
slow_90firebird
