IowaCummins wrote:just blend it to match?
IrishChamp wrote:So what you're getting at is that turbulence is bad and that I need a smooth transition?
dunes450r wrote:IrishChamp wrote:So what you're getting at is that turbulence is bad and that I need a smooth transition?
turbulence is a bad thing if you're looking to make max power/tq. it will run just fine if you didn't do anything though. you'd just be missing a little potential power
IrishChamp wrote:Will it create a bunch of extra heat? I'm not looking to make max power right now, I'd need head studs to make any power.dunes450r wrote:IrishChamp wrote:So what you're getting at is that turbulence is bad and that I need a smooth transition?
You don't need head studs to make power, really high boost then yes head studs will help, but i think 350hp is pretty doable with the stock gasket and head bolts. especially if you re torqued them.
