Project ugly duckling
Postby dazedandconfused » Sat Mar 12, 2011 4:00 pm
Well went and picked up a 83 half ton dodge today after visiting KTA and dropping off some parts to him. Its a solid little truck for the age. Its name comes from the ugly brown color of it.
Re: Project ugly duckling
Postby ellis93 » Sat Mar 12, 2011 5:49 pm
What's the plan for it?
Postby oldestof11 » Sat Mar 12, 2011 6:16 pm
Awesome truck!
Looks real solid! :twisted:
Postby dazedandconfused » Sat Mar 12, 2011 6:42 pm
It will be a drag truck/toy. I found this one after getting screwed out of the other one. Read this other thread to get caught up on how I ended up with this truck. Its pretty solid for a 28 year old truck.
http://www.1stgen.org/viewtopic.php?f=32&t=9952
Postby Tacoclaw » Sat Mar 12, 2011 7:19 pm
If you don't mind the derail, how did you get those pictures to thumbnail like that? I quoted you, and it seems like you have both IMG and direct links of the same pics.
Any explanations, or better yet, shortcuts on how you did it?
Postby dazedandconfused » Sat Mar 12, 2011 7:54 pm
I just clicked the thumbnail link on photobucket
Postby thumpertrev » Sat Mar 12, 2011 10:03 pm
Ive always like those Wheels. Had a set on an old 280zx. Good lookin truck.
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby oldestof11 » Sun Mar 13, 2011 6:09 am
Tacoclaw, Photobucket has a list of links when you click on the picture in your PB account to the lower right. It has a thumbnail link. Use that to "thumbnail".
Postby Tacoclaw » Sun Mar 13, 2011 7:48 am
Alright, I got it, thanks guys. :D
I had to didn't have the option for thumbnails checked. Only took me about an hour to find out how to fix it. :lol:
Back on topic, Sweet truck. Can't wait to see what you do to it.
Postby dazedandconfused » Sun Mar 13, 2011 7:55 am
Plans are to use my 93 D250 to repower it. Built auto, twins etc. Would you guys build up a 5 lug dana 60 or build a 9" to go under it. I know the 60 will hold since that's what is under the little red cummins express truck.
Postby oldestof11 » Sun Mar 13, 2011 10:04 am
Wellllllllllll...............
The aftermarket support for both is BIG. I would consider a 10b also. If you can deal with 8 lugs in back, I would DEFINITELY do a 14B. More of them out there, huge market support, and cheaper to build...
Postby dazedandconfused » Sun Mar 13, 2011 10:22 am
I want to keep it 5 lug
Postby RumbleFish » Sun Mar 13, 2011 11:06 am
You can find a Chrysler 8 3/4 from a 70s truck that will bolt right in and quite strong also.
Postby Mark Nixon » Sun Mar 13, 2011 8:17 pm
Run a Mopar 9-1/4 with the A-7 (tapered roller) axle bearing conversion.
The 8-3/4 doesn't have enough root strength on the ring gear for the steady and high torque the diesel will abuse it with.
Another, much better, option would be a custom Dana 70, or 35 spline Dana 80, converted to semi-floating axles with billet 5 lug 35 spline axles and over-sized wheel studs.
Either of these options (D70, D80 or 9-1/4) will require new housing ends and a few $$$ outlay, but you would be better off in the long run, at least on the Dana axles, anyway.
Postby dazedandconfused » Mon Mar 14, 2011 6:10 am
Mark care to elaborate on how to change the 70 over to semi floating 5 lug since I already have a 70 under the 93.
Users browsing this forum: No registered users and 75 guests
