Remps wrote:Got some more info on it: The price is 2700 to 3500 depending on bell and whistles. The system is the turbo with the turbine housing with the vane and delphi actuator, the standalone programmable turbo computer, a cahn unit to let the computer and your laptop communicate. This allows you to log data such as backpressure, boost pressure, throttle position, turbo rpm, egt's, and vane position. You can view all of this in real time on your laptop. For most applications controlling the vane using backpressure data works very well and this sensor is included in the lower price. The 63 mm compressor wheel is rated by Borg Warner at 75 lbs/minute by weight. Supposed to go on sale in a few weeks.
The_Head wrote:Remps wrote:Got some more info on it: The price is 2700 to 3500 depending on bell and whistles. The system is the turbo with the turbine housing with the vane and delphi actuator, the standalone programmable turbo computer, a cahn unit to let the computer and your laptop communicate. This allows you to log data such as backpressure, boost pressure, throttle position, turbo rpm, egt's, and vane position. You can view all of this in real time on your laptop. For most applications controlling the vane using backpressure data works very well and this sensor is included in the lower price. The 63 mm compressor wheel is rated by Borg Warner at 75 lbs/minute by weight. Supposed to go on sale in a few weeks.
Whoa. Way too much electronics for a first gen. (j/k)
