Shift Kit
Re: Shift Kit
Postby JustinRhodes » Sat Mar 19, 2011 7:50 am
So with a manual valve body, say your going like 45mph then you slow down to 20 and leave it in drive, could you lug it back up to 45 in drive or would it downshift for you?
JustinRhodes
Re: Shift Kit
Postby dazedandconfused » Sat Mar 19, 2011 8:36 am
It won't shift unless you shift it.
Re: Shift Kit
Postby JustinRhodes » Sat Mar 19, 2011 9:45 am
dazedandconfused wrote:It won't shift unless you shift it.
heh thats pretty cool
how does the overdrive work?
JustinRhodes
Re: Shift Kit
Postby dazedandconfused » Sat Mar 19, 2011 11:17 am
Wire it to a switch and manually control it. Remember it's still an auto and you can burn it up still by lugging it to much.
Re: Shift Kit
Postby JustinRhodes » Sat Mar 19, 2011 3:13 pm
dazedandconfused wrote:Wire it to a switch and manually control it. Remember it's still an auto and you can burn it up still by lugging it to much.
oh ok, i was just wondering, im not going to be doing this, i have a 518 in my truck now thats junk. im swapping to a 5spd though
JustinRhodes
Re: Shift Kit
Postby dazedandconfused » Sat Mar 19, 2011 3:27 pm
Your truck 4X4 or 4x2
Re: Shift Kit
Postby JustinRhodes » Sat Mar 19, 2011 4:00 pm
dazedandconfused wrote:Your truck 4X4 or 4x2
4x4
if you know anyone that has 5spd 4x4 swap stuff let me know.
JustinRhodes
Re: Shift Kit
Postby dazedandconfused » Sat Mar 19, 2011 4:05 pm
I'll keep my eyes open for you.
Re: Shift Kit
Postby CaseyF » Sat Mar 19, 2011 9:54 pm
How do you hook up a floor shifter to the linkage for the trans?
1992 W350 flat bed. GlowShift Gauges, 3.54 gear, Full Power Screw bottomed, DennyT Pump Top Delete, 366 GSK, Custom CAI, Pro Comp fuel pump, DE 4'' Exhaust, 14cm Exhaust Housing, Getrag.
CaseyF
Re: Shift Kit
Postby jughead » Tue Mar 22, 2011 3:57 am
only use 3rd normally with my 82. 3.21 axle and it does real well for normal driving. when i get the od i will have to be careful with od dont think it will stand the torgue of the engine. i will have to remember turn it off when i stop. i only use the gears on the 3 speed when showing off.
jughead
Re: Shift Kit
Postby CaseyF » Tue Mar 22, 2011 1:29 pm
Does it still pull the same or harder?
CaseyF
Re: Shift Kit
Postby dazedandconfused » Tue Mar 22, 2011 4:14 pm
You run a full manual in third all the time?
Re: Shift Kit
Postby jughead » Tue Mar 22, 2011 4:45 pm
have been running it in 3rd for about 7 years. had to pull it once because this dumb old man let it run low on fluid. they just dont live too long low on fluid. i have done burn outs that most people dont believe. 3rd gear only a measured 349 ft. 500 plus ft lbs of torgue will do more than most gassers will do in low gear. i have played with these transmissions since 1965. 3rd gear will handle more than most street tires will
jughead
Re: Shift Kit
Postby 91bluecummins » Tue Mar 22, 2011 5:02 pm
can some one find me a link to a 518 man vb reversed kit i cant seem to find one
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: Shift Kit
Postby dazedandconfused » Tue Mar 22, 2011 6:08 pm
Call A&A transmissions.
Return to Transmission
