Shakey
Shakey
Postby mhuppertz » Mon Apr 04, 2011 9:00 pm
I have a front end shake that is the same regardless of tire age. I can't find it. My steering is fine, tired are wearing pretty evenly. This is with the hubs unlocked or locked. I can have the tires rotated and rebalanced and it is exactly the same. Running American Racing wheels. Making me crazy.
mhuppertz
Re: Shakey
Postby ahale2772 » Tue Apr 05, 2011 5:42 am
I had my kingpins apart a while back and they were more worn than I would have expected. I did the sensible "try to shake the hub up and down on the truck" to see if they were worn but no dice because they are quite tight....regarless I rebuilt them and my left front stopped shaking ...might be worth a look :grin:
Re: Shakey
Postby mhuppertz » Tue Apr 05, 2011 7:07 pm
ahale2772 wrote:I had my kingpins apart a while back and they were more worn than I would have expected. I did the sensible "try to shake the hub up and down on the truck" to see if they were worn but no dice because they are quite tight....regarless I rebuilt them and my left front stopped shaking ...might be worth a look :grin:
I know I need a piece of 3/4" hex to unscrew the king pins, but what other tools do I need?
mhuppertz
Re: Shakey
Postby ahale2772 » Wed Apr 06, 2011 8:41 am
I never even pulled the kinpins themselves, i believe they are tourqued to like 150ftlbsn :shock:
other than that big hex there are no special tools
what was worn on mine was the plastic collar piece, I got a rebuild kit from napa for pretty cheep
Re: Shakey
Postby mhuppertz » Sun Apr 10, 2011 4:37 pm
I started my truck and twisted the borgesson while looking at the front end. The tie rod link on the drivers side had at least 1/8" of slop, and the other side and drag link ball joints were also shot. I replaced all of them and got rid of the shake, but I still have the shimmy at speed. I just ordered a complete kingping rebuild kit and the 3/4" hex wrench to get the uppers out. I can tell my king pins are shot because it is wearing the inside on the tires a bit. Have a feeling I will have to put a 6' cheater on the hex wrench to get the things loose.... steering is really tight now.
mhuppertz
Re: Shakey
Postby ahale2772 » Mon Apr 11, 2011 5:27 am
yeah that was the same as mine, aligned it 4 times to make sure I wasnt crazy and it was still wearing the insides of the tires
Re: Shakey
Postby Raymo » Tue Apr 12, 2011 7:27 am
mhuppertz wrote: Have a feeling I will have to put a 6' cheater on the hex wrench to get the things loose....
Take a cut-off wheel and cut around the base of the kingpin, but leave enough to not snap it off while turning it (Try .250" or so) . Makes childs play of removing those stubborn b*stards.
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
