KTA wrote:I think 2 things cause the seizures. #1 to small of an injector to cope with the fuel flow so injection pressures get to high and you distort the barrel and plunger from hydraulic pressure. Since the barrel is thinner in a 14mm since it is a bored out 12mm it more easily distorts. #2 is lack of fuel. If you look at the fuel inlet size in the VE plunger you will see it is very small. By design this hole can not be enlarged and it has to be the same size for a 12mm and a 14mm. This is going to require a special fuel system and some serious reengineering to solve.
KTA wrote:I don't have any 6x.016 injectors that would meet that criteria so no I have never tested that.
