Engine Shake After 366 Spring Install
Postby 1990 » Sat Apr 30, 2011 4:06 pm
I don't know if the spring install has anything to do with the shake. It didn't have this symptom immediately after installing the spring.
The shake is a tad worse at idle now then it was stock. As soon as i raise the RPM (not very much) it gets real bad. The engine mounts look good and where just change last August.
Any help would be great!
Thanks
Video
I have my elbow on the battery. The camera is shaking pretty good.
2012 Subaru WRX TP Stage 1 DD
Re: Engine Shake After 366 Spring Install
Postby 1990 » Sat Apr 30, 2011 5:06 pm
I let it idle for a bit and it cleared it self up. Air lock?
Postby BobS » Sun May 01, 2011 4:51 am
Trapped air in the high pressure side is a common occurrence anytime the high pressure side is opened. You can get most of it out manually enough to get the engine started but the system usually needs to self purge itself.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby 1990 » Mon May 02, 2011 5:51 am
Okay. Everything has been running smoothly since.
Thanks
