Ptothej wrote:in the mean time.. worth while to up the charge pipes to 3" with factory intercooler?
Tacoclaw wrote:Looking at your sig, I don't see any mention on injectors. Aren't ICed injectors known to be on the small side? I can't imagine you'd need a different turbo to cool them.
Horus wrote:(Crawls out slowly from behind the thread)
I, well, have a confession to make.
My pyro is post-turbo. I've seen mine around 1000 degrees a few times towing. The most it has ever been was just under 1100 as the needle showed. I didn't know pre and post turbo numbers were so different.
I'm scared.
I'm scared.
