tach install
tach install
Postby casanova909 » Tue Jun 28, 2011 6:33 am
i was wonderin what a person all has to do to put a tach in a 92. i have a 4 grand isspro tach with four wires iv heard that i need some kind of a harnnes but i dont really know so if anyone knows let me know thanks
92 W250, BullyDog fuel pin, 3200 governor spring, pump turned up slightly, AFE cold air intake, strait piped
{Crazy Cowboy}
casanova909
Re: tach install
Postby collegekid » Tue Jun 28, 2011 7:41 am
You dont need the harness if youre handy with the wires, theres a tech article somewhere that I read that gave the breakdown of where each wire goes, just do a google search
collegekid
Re: tach install
Postby BILTIT » Tue Jun 28, 2011 10:20 am
In a 92 you can buy a harness to wire it. I just put one in my 91 by wiring it in, not too bad.
This is the harness you can buy:
http://www.isspro.com/proddetail.php?prod=R8912-92
As said above there is an article somewhere about making one yourself.
See here:
http://www.dieseltruckresource.com/dev/ ... ostcount=3
Derek B.
BILTIT
Re: tach install
Postby dazedandconfused » Tue Jun 28, 2011 12:42 pm
Anybody know how to wire up a 93?
Re: tach install
Postby BILTIT » Tue Jun 28, 2011 3:30 pm
Pretty sure its same as a 92.
Derek B.
BILTIT
Re: tach install
Postby 921stgen » Tue Jul 05, 2011 6:25 pm
Dazedandconfused, heres how BC847 did his 93.
http://www.dieseltruckresource.com/dev/ ... p?t=173561
91 W250 pods, , pull cable, Isspro FP gauge, Isspro boost, pyro, 366 spring, 91 W350, sold-92 W250, 40 hp Injectors, Bully Dog Fuel Pin, Isspro-tach, boots, pyro, AM electric fp gauge, 3200 GS, 5" AEM intake, 4" exhaust 5" stack
921stgen
Re: tach install
Postby Richie O » Tue Jul 05, 2011 7:53 pm
Re: tach install
Postby casanova909 » Sun Jul 24, 2011 10:01 am
thanks for all the replys sorry i havent been on to thank yall earier i havent had a chance to laitly
but thanks everyone
{Crazy Cowboy}
casanova909
Re: tach install
Postby dazedandconfused » Sun Oct 30, 2011 10:26 am
Well I guess my tach isn't gonna work. Been messing with it but won't read.
Re: tach install
Postby Brad717 » Sun Dec 11, 2011 6:26 am
I looked and found a connector tape to my wiring harness and ordered a Tach because of what I read here and other sites. And it said it would work on a 1991.5
Yes I ordered before I did my homework
I just found some of the adds selling Tach to be a little misleading
According to service manual for a 1991 that plug taped to wiring harness near fuse box has 3 wires and is for “Snowplow Previsions”. Also there is no reference to any changes in the 1991.5 Service Manual Supplement.
Wiring 91 91.5 dash
http://carrollcitizens.com/files/Wiring_Tach.pdf
UPDATE- I found were SomeOne explains how to wire the alternator.
http://www.turbodieselregister.com/forums/1st-generation-ram-forum-1989-1993/132600-wiring-alternator-tach-drive.html
or buy the crank sensor
http://www.dnrcustoms.com/zen2/index.php?main_page=index&cPath=34_37_52
Thanks
91.5 W250 5spd - 1/8 bump, DT 2, 3200, PT NoSlip
Brad717
Re: tach install
Postby 91flatbed » Tue Jan 17, 2012 11:22 pm
Just got a sunpro tach for christmas (i know not thge greatest in the world) do you think that wiring diagram for that 4 pin connector could work the same way with my sunpro?
91flatbed
Re: tach install
Postby ahale2772 » Wed Jan 18, 2012 8:13 am
your sun tach should come with a diagram no?
Re: tach install
Postby revemup15 » Fri Mar 30, 2012 8:55 pm
I have a 89.... do I have the plug?
94 p-pump
revemup15
Banned
Return to Electrical
Users browsing this forum: No registered users and 62 guests
