P-Pump conversion, Parts list
Postby Hansen01 » Wed Jul 06, 2011 10:14 pm
jus wondering what was all going to need changed on my 90 to run a P-Pump?
(may not get done tomorrow, but its gonna get done eventually) :D
Under construction...
Hansen01
Re: P-Pump conversion, Parts list
Postby gobigorgohome » Wed Jul 06, 2011 10:16 pm
not sure on the list exactly but i know a p pumper can be aquired from an 8.3 cummins too. gears anwhat not may be different but they have a p7100 on em
gobigorgohome
Postby skilletky » Thu Jul 07, 2011 6:35 am
Front gear case, inj lines, injectors, throttle linkage, gotta pull the cam to swap the gear case.
skilletky
Postby Mark Nixon » Thu Jul 07, 2011 8:43 am
I have a whole 1995 engine for as much as the conversion will run.
It has around 300,000 miles on it and it runs okay, just needs a re-seal and it wouldn't hurt to throw a set of rings and bearings at it, too.
Or you could buy it and pirate the conversion off it. :D
Or I could just part the engine out, someone here needs a head....
Postby Hansen01 » Thu Jul 07, 2011 3:14 pm
thanks guys! :D
Hansen01
Postby Hansen01 » Fri Jul 08, 2011 3:53 pm
also would the injectors fit right into my head or would you need adapters or somethin?
Hansen01
Postby skilletky » Fri Jul 08, 2011 6:57 pm
Pretty sure the only difference in a p pump injector and a intercooled ve injector is the nop and the threads for the high pressure fuel line on a p pump injector are bigger. I think both are a 7mm tip with a 145 degree spray angle
skilletky
Postby Hansen01 » Fri Jul 08, 2011 10:51 pm
i do not have the intercooled pickup if that matters
Hansen01
Postby skilletky » Sat Jul 09, 2011 8:10 am
The pistons in a non intercooled motor are different, injectors in a non ic use a 155 degree I think. You will probably be better off swapping in a compleat p pump motor
skilletky
Postby mathews8pt » Sat Jul 09, 2011 8:48 am
It wouldnt be as bad running a 145* injector in a motor built for 155*, as it would be running a 155* injector in a 145* piston. I believe you can just use p-pump injectors with the adapters for your 9mm head.
I would just find a p-pumped engine if it were me...
2000 p-pumped 24v daily driver
1993 D250, 2wd, 5spd(for now), timed to head, hx35, PODs, electric fuel pump, ground pin. The new project truck...
mathews8pt
Postby Hansen01 » Sat Jul 09, 2011 9:25 am
could i not jus get the spray angle changes,say different tips when they get rebuilt?
Hansen01
Postby Dave 5.9 » Tue Mar 25, 2014 6:53 am
Are the cams the same? I have a 94 p pump going onto a 91 intercooled block. Do I use the 94 or 91 cam????
Dave 5.9
smoke screw?
