Finished filling and matching my T6 flange:
Justin: Yeah, it hasn't moved. Nothing I work on stays in the same place as I work, but it's supposed to be in the same spot, and it's definitely in the same area as it started.
AHineman wrote:Keep it up...
I try to help and this is the thanks I get.![]()
Don't worry, when you get done you'll have the 2nd highest horsepower VE truck in Gallia county.
Hint on the 1st...it's a green 2wd.
JustinRhodes wrote:my truck aint green or 2wd?
)Remps wrote:What size of turbine wheel is on that S475?
