3 and 1 gauges
Re: 3 and 1 gauges
Postby flyinredneck » Fri Jul 15, 2011 10:10 am
when you you drilled and tapped you egt probe did you do it with the engine running or just suck the shavings out?
1992 w250 stock straight pipe with pump a lil tweaked denny t stage 2 fuel pin fuel screw at 3 turns
flyinredneck
Re: 3 and 1 gauges
Postby flyinredneck » Fri Jul 15, 2011 9:46 pm
what does your boost run at
flyinredneck
Re: 3 and 1 gauges
Postby 1990 » Sat Jul 16, 2011 10:34 am
1/8 NPT Extender
Vacuum and magnet
20 PSI STOCK (Non I/C)
2012 Subaru WRX TP Stage 1 DD
