I see fuel leaking under the truck so I check the pump and its leaking from the bottom at the rear by the pump head, looks like the oring between the head and pump body.
I try to start it again thinking a fuel leak is one thing but no start is another, and now it just almost starts but wont.
I checked the solenoid and its ok, with no power the truck is no start at all, with it on it tries and almost goes.
So I checked and plenty of fuel flow, I have a Carter electric pump.
It does get fuel thru the lines as I pulled them off and checked, but obviously not enough pressure to start it.
It then started to leak from the manual turn off lever on the side and then the top at the throttle lever seal itself.
Its like it has some internal pressure leak that is blowing fuel back into the case body and not all the fuel and pressure is going thru the pump and lines on the high pressure side.
I don't know enough about these pumps to guess but anyone seen this type of symptoms ?
The pump was pulled from a wrecked 93 truck, my setup is an 89, injectors lines etc.
Its been on my truck for right at 1k miles and no issues at all till now.
Any help would be appreciated !
I dont want to take this to a shop and get charged 800 bucks to reseal it
Thanks,
Scott
