PToombs wrote:Mr. Ellis, there are lots of worse people to be grouped with.
txs wrote:back to original topic, mark already mentioned the lockup converters on the 47rh, the 2 other differences are the the 47 has a steel front carrier and the biggest difference of all three, double wrap reverse band, the carrier and lockup can be upgraded to in the 518.
Kasper Cummins wrote:Am I reading this right, there is a way to make a 518 lockup? Just swap the 47rh lockup parts in the 518 case and run the wires?
