VE 14mm CUMMINS POWERED OLIVER SUPER 88
Postby mauss440 » Mon Aug 22, 2011 6:29 pm
1956 oliver super 88 pulling tractor.
VE 14mm powered.
mauss440
Re: VE 14mm CUMMINS POWERED OLIVER SUPER 88
Postby pulltilbroke » Mon Aug 22, 2011 8:01 pm
Thats awesome and its the right color of green. :D
Postby Kasper Cummins » Mon Aug 22, 2011 8:06 pm
That's an awesome tractor. But why are they using the VE pump if they are spending that much money on it. Don't get me wrong its cool that its running the VE but for the money spent why did they not go p-pump or common rail?
92 W250 club cab
Kasper Cummins
Postby mauss440 » Mon Aug 22, 2011 8:07 pm
RULES................. It is what i can run at this time.. No worries it WILL be P-PUMPED.
mauss440
Postby Kasper Cummins » Mon Aug 22, 2011 8:17 pm
Rule only get in the way. The tractors can get wild my grandpa and uncle have 4 tractors that are only used to pull. Gandpas have $10,000 spent in one of his this year and my uncles got a new motor, I'm told it has 400hp more then the old one.
92 W250 club cab
Kasper Cummins
Postby Richie O » Mon Aug 22, 2011 8:25 pm
You better film it, I wanna see. :D
Postby 1STGENFARMBOY » Mon Aug 22, 2011 9:17 pm
My friend this is what an OLIVER power plant is supposed to look like.
I'm just kidding of corse.....that 88 is super cool, what class are you gonna pull in ? ?
Dar
Postby mauss440 » Mon Aug 22, 2011 9:57 pm
5700 6200 hot farm this summer. see what next year brings.
mauss440
Postby cmann250 » Tue Aug 23, 2011 5:36 am
Nice set-up. That's a far cry from the Super 77 and 880 diesel we use to bale hay
Postby mauss440 » Tue Aug 23, 2011 11:45 am
THIS WAS USABLE A YEAR AGO ON THE FARM. I JUST PULLED THE PTO OUT WHEN THE MOTOR WAS TUNED UP A LITTLE BIT.. 66/74/90 BILLET WHEEL NO WASTEGATE , 5X18 INJECTORS, VERY TUNED CYLIDER HEAD..AND SOME FUEL. AND MUCH MORE.
mauss440
Postby 1STGENFARMBOY » Tue Aug 23, 2011 11:55 am
Whatcha doin to the other one sittin beside that one.
Dar
Postby dazedandconfused » Tue Aug 23, 2011 12:55 pm
That's cool! Are you RPM limited or pump limited?
Postby mauss440 » Tue Aug 23, 2011 3:43 pm
88 next to it is waiting for some parts to hit the track..
mauss440
Postby mauss440 » Tue Aug 23, 2011 3:45 pm
limited to pump. This VE will run 44-4500.Scheid Diesel sold me the pump and injectors.
mauss440
Postby 1stgenblowingsmoke » Wed Aug 24, 2011 2:30 pm
What is with that intake on that cummins?
90 LE 250 reg cab 4x4 5 speed getrag. Fuel screw turned to factory stop, throttle rod mod, 3.5in flow through exhaust, #75 fuel pin rotated, HX-35 waiting to on along with an intercooler.
1stgenblowingsmoke
Return to Competition
