What do I need to make 500-550HP
Postby nova6511 » Sun Aug 21, 2011 6:55 pm
Ok for my winter build for next season pulling I would like to make 500-550 HP with the VE can I do it with the 12mm head.I can get a p-pump set up but you guys here have rubbed off on me and know it dont seem like a fisrt gen if I do that.Any ideas or info would be aprreciated.
nova6511
Re: What do I need to make 500-550HP
Postby Richie O » Mon Aug 22, 2011 4:34 pm
500 on stock IP, nope. You would be lucky to get 450 with extensive head work, cam, ect.
Postby RumbleFish » Mon Aug 22, 2011 5:08 pm
Buy bill gilberts truck. Call it a day.
Postby nova6511 » Mon Aug 22, 2011 6:05 pm
Thanks for the help looks like I will be P-pumping it this winter.
nova6511
Postby oldestof11 » Mon Aug 22, 2011 7:10 pm
Well now, don't get butt hurt! :roll:
What is it you are looking for info wise?
Postby Kasper Cummins » Mon Aug 22, 2011 7:46 pm
KTA made 480hp with 12mm h/r. So with alot of work and alot of help 450-500hp is doable.
Check up KTAs post about injection pump test, it has good info of what the injection pump can do.
What class are u looking to pull in, because a single turbo with 500hp VE may take some time to spool on the street.
92 W250 club cab
Kasper Cummins
Postby BC847 » Mon Aug 22, 2011 7:48 pm
RumbleFish wrote:Buy bill gilberts truck. Call it a day.
Not to be slamming Bill's ride, but big numbers on a dyno doesn't necessarily work out to big numbers on the track.
Postby nova6511 » Tue Aug 23, 2011 6:36 am
Not butt hert,looking for injector ideas,turbo best for the job.I know I need studs,valve springs and big fuel system.I will be going to eaither a 4 speed manual with a devorced transfer or a 47rh.The truck will see very little street time next year.
nova6511
Postby oldestof11 » Tue Aug 23, 2011 12:50 pm
I just saw this and thought "2.6" VE are now possible..."
http://www.southerndieselx.com/product_ ... ducts_id=3
For $550, this maybe what a VE needs to get competitive.
If you want an explanation, let me know. I can 'splain it.
Postby nova6511 » Tue Aug 23, 2011 1:50 pm
Please explain.Thanks
nova6511
Postby oldestof11 » Tue Aug 23, 2011 1:57 pm
With a DIVIDED turbo exhaust housing, exhaust goes to both sides of the divide. Now, adding this helps to improve the spool up of the turbo by diverting the all gasses to hit the exducer (biggest part of the turbine "fan") thus improving spool up. Kinda like taking a garden hose and covering half of the end with your thumb.
Once boost hits a certain #, it starts opening the flapper allowing full flow of the compressor without getting drive pressure and EGT's too high.
I read 10-15#'s it starts opening and 30-40#'s fully open.
Postby nova6511 » Tue Aug 23, 2011 3:25 pm
I like it, know I need a big turbo.I have a big garrett but every one around hear says it is way to big for a single.It is off a 6v71 and is brand new.Thank you for the info and the idea.
nova6511
Postby oldestof11 » Tue Aug 23, 2011 3:34 pm
It will probably have a T6 foot. As of right now, there isn't one made for that AFAIK. Whats the model number?
Postby dazedandconfused » Tue Aug 23, 2011 3:37 pm
I'd run the 47RH so you have the option to downshift and keep the rpms up.
Postby oldestof11 » Tue Aug 23, 2011 3:38 pm
If it is a GT4094R, then the compressor wheel looks too big to pass tech... :?
Anyone know if a 68mm inducer would pass as-is? Meaning no stepped or custom covers?
