Speed-o problems???
Speed-o problems???
Postby Jer12377 » Sat Aug 20, 2011 11:12 am
My speed-o would kick out once and a while before but, now it dosen't work more than it does. Where should I start looking to solve this?? I drive a 93 W350 5spd.
93 W350 5spd, ARP studs, Denny T pin, 3200 RPM spring, Boost, Pyro, fuel, and head temp gauges, Amsoil BHAF, PS intercooler, HE351CW turbo, custom 3" intake tubes, 4" home made exhaust, Re-built GETRAG, Dana 80 with an ARB air locker....
Jer12377
Location: North Haven, CT "Living in occupied territory"
Re: Speed-o problems???
Postby ellis93 » Sat Aug 20, 2011 5:40 pm
If your truck has cruise,does it work when the meter is out. If it does then its the speedometer. If not There is a 90degree adapter and a reduction gear box under mine and I've found it loose before. The speed sensor should screw into the reduction gear box, assuming that your 4wheel is set up similar to mine. Check and see if all of it is tight. Also check for a broken wire. If it all looks good then its probably the speed sensor.
Postby Jer12377 » Sun Aug 21, 2011 3:19 pm
No cruise, and I do have that gear reduction box on my transfer case. Can I get a speed sensor or is there any way of testing it? I still have to have my rear drive shaft balanced and install my new front so Im getting under there as soon as I get a chance.
Jer12377
Postby Mark Nixon » Thu Aug 25, 2011 7:48 am
It's likely it's the gear reduction box.
A simple test to see is to take the box off and run the VSS directly on the trans, if the speedo works, you found the culprit.
Postby Jer12377 » Thu Aug 25, 2011 6:38 pm
I went under her today and took the gear box and sensor assembly off. I also bought a new sensor cause the nut on the one on the truck had seen a better day. Although the box is cracked, it still works. However I have a few divorced transfer-cases from the early 70's Power Wagons I had and one has a aluminum reduction gear box with what seems to be the same ratio. It was seized and the square drive was broken off so Im in the process of fixing it. Oh and if you have a 93 and go to Advanced to get a speed sensor, they list it as 91 to 92 and only the automatic transmission sensor for the 93's.
Jer12377
Postby manyholes » Tue Aug 30, 2011 11:00 pm
whats the link for advanced? i havent been able to track a speed box down ,up here in canada
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Postby Jer12377 » Fri Sep 02, 2011 6:02 pm
manyholes wrote:whats the link for advanced? i havent been able to track a speed box down ,up here in canada
They don't make the reduction box any more but, you can get the speed sensor that attaches to it. Advanced Auto Parts has the sensor, I don't have the link right now. The reduction box from one of my 74 Power Wagons I had with the divorced transfer case works. I have 3:54s and my 74 had 3:53s. If you can find someone with old parts grab the box. I had to rebuild mine cause the grease was all hard inside and seized everything but, I works now.
Jer12377
Postby Mark Nixon » Fri Sep 02, 2011 8:38 pm
This link might help you guys, what you want is about 1/8 of the page down:
http://www.transmissioncenter.net/speed ... %20adapter
Postby dragrdan » Mon Oct 31, 2011 3:41 pm
Anyone know what the original reduction or overdrive is used on our trucks. G360 and 3.55s
93 W250 5spd, Comp 275, HE351CW, 5X18, IP turned up, 3200 spring, BHAF.
dragrdan
Return to Electrical
