Re: Next stage- Twins (last page)
Postby Tacoclaw » Wed Aug 31, 2011 6:01 am
Hansen01 wrote:the getrag is light compared to the nv5600 ;)
Yeah, but that's like complaining your girlfriend weighs 10 more pounds, but it all went to her tits. :lol:
Postby Hansen01 » Wed Aug 31, 2011 2:13 pm
i wont argue with that :D
Under construction...
Hansen01
Postby Tacoclaw » Sat Sep 03, 2011 4:37 pm
Experimental drain line setup: Complete.
Took NPT pipe and turned down a lip in the end:
Knocked off some of the rust off my milling skills and chewed a hole out of the side. I matched it with a burr grinder.
Yes, I'm a terrible welder. :oops: Burnt through twice, but after a couple tries and many trips to the grinder it seems solid.
Due to us having a pit, the oil filter won't be too much of a bear to get to.
NPT 1" 90* to a 1" 45*, then to the "T" I made. The 90* is the only part that makes me nervous about this setup. If it doesn't seem to like to drain, I'll pull it and port on it with a burr, then try again. If that doesn't work, I'll have to go back to the drawing board.
I've got heat tubing to go around all these hoses, and plan on running a blanket on the T6 turbo at least, so the silicone hose should be fine.
Postby AHineman » Sat Sep 03, 2011 5:01 pm
Drains were a pain in the butt for mine too. What do you have to do before you can start it?
Postby Tacoclaw » Sat Sep 03, 2011 6:10 pm
Not a lot actually. To start it that is.
I figure I'll slap some RTV on the drain flanges and fire it up. There's no water in it, but I just wanna see them spin. Is that too much to ask? :lol:
[edit] Started it today. It was good to hear the old girl rattling around again. No gaskets anywhere on the exhaust tract and everything was a little loose, but the S400 did start spinning once I gave it a little spin-start. :lol: I hope to have the downpipe tacked up and maybe a wastegate dump run into it by tomorrow. [/edit]
Postby Tacoclaw » Sat Sep 10, 2011 8:11 pm
Grabbed a couple of pics of my downpipe for Hineman.
It just seems like I never have enough 90*s on this thing, huh? :lol:
It drops right back into my previous exhaust setup, so that's easy enough. I'm gonna wrap the 5" section only, I just wish I had the room for a full 5" exhaust...
Postby AHineman » Sat Sep 10, 2011 9:05 pm
Tacoclaw wrote:Grabbed a couple of pics of my downpipe for Hineman.
Thanks. It looks sweet. 8)
Tacoclaw wrote:I just wish I had the room for a full 5" exhaust...
:P
Postby Tacoclaw » Sun Sep 11, 2011 3:53 pm
:P
I'll keep this in mind the next time you need pulled out of some wet grass. :lol:
Postby JustinRhodes » Sun Sep 11, 2011 5:25 pm
:P
haha i have to get out and lock my truck in 4wd all the time in wet grass, i figured the new tires would help but i guess i was wrong lol
also good to see the twins are getting close to being finished up levi :D
JustinRhodes
Postby AHineman » Sun Sep 11, 2011 8:43 pm
The guy with no posi? :lol:
That last ride you took in it must have scared you so bad you forgot both back tires were spinning. :P
Postby PToombs » Mon Sep 12, 2011 5:30 pm
Ah yes, wet grass. The bane of the D250 1 wheel peel crowd! :oops:
Postby ellis93 » Mon Sep 12, 2011 8:40 pm
Wet grass, loose gravel, sand, 1/4" thick mud. :roll:
Postby PToombs » Tue Sep 13, 2011 5:36 pm
Them too! :lol:
Postby Tacoclaw » Mon Sep 19, 2011 6:09 pm
Ordered a set of blankets for my setup. I got an S400 wrap, custom manifold wrap(due to the Steedspeed externally 'gated manifold), and hotpipe wrap for $100 more than the S400 wrap I was previously looking at. I can't say enough good things about Levi(He's got a good name too) at Turbo Performance Products. He's been emailing me back and forth for about a week now making sure everything is going to fit right before it's sent.
I'm gonna grab some mandrel-bent pipe tonight tor the wastegate dump and start getting it back together. I may just get to take it for a spin before winter rolls around.
Postby ahale2772 » Wed Sep 21, 2011 4:00 am
.....................YUH THINK??? :grin:
no way I could mock up a set of twins and let them simmer till next summer
Lookin good BTW, I like the downpipe
all u guys doing twins makes me NOT want to do twins... I could have it mocked up weleded and looking good in no-time... but the tuning/ fixing leaks part makes me want to rip out my hair :mad:
