Little gauge project
Re: Little gauge project
Postby lifted_drifter » Fri Apr 01, 2011 4:46 pm
okay. well thanks for the info man.
and i think your gauge setup is pretty sweet.
lifted_drifter
Postby Tsbourne09 » Wed Sep 28, 2011 5:36 pm
Got this from http://www.whitegauges.net i know its dirty and needs cleaned, also flash is super bright.
at night, bulbs also came from http://www.whitegauges.net
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Wed Sep 28, 2011 5:41 pm
Not On Yet: 60#VS
Tsbourne09
Postby PToombs » Wed Sep 28, 2011 5:45 pm
I like the white face gauges, but for some reason they just don't look quite right in the dash. Like the dash is too dark or something. Maybe I'm just acclimated to having the black dash for the last 40 or so years.
I still might get a set of those stickers.
Postby Tsbourne09 » Thu Sep 29, 2011 2:10 am
looks bad in pic but in daytime when everything is nice and clean they look cool and neat. and they are extreamly difficult to put on. gotta get on and around needle without touching the sticky part to anything. i wouldnt do it again. i took a sharpie to my needles to brighten them up.
Not On Yet: 60#VS
Tsbourne09
Postby firstgenjunkie » Thu Sep 29, 2011 8:54 am
Gots_a_sol wrote:Well I am sitting here with a broken leg, so I have tons of free time on my hands for little projects like this.
Found a black light to play with. Holy crap. I might have to see about using one of those instead of the factory setup to illuminate this thing :lol:
You know you could replace the illumination bulbs with ultraviolet (black light) ones....from superbright led they run about $1.40 for the wide angle single led up to about $3.75 for six leds.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Postby Tsbourne09 » Thu Sep 29, 2011 2:59 pm
wow those are cool. and cheap.
Not On Yet: 60#VS
Tsbourne09
Postby Gots_a_sol » Thu Sep 29, 2011 5:12 pm
firstgenjunkie wrote:You know you could replace the illumination bulbs with ultraviolet (black light) ones....from superbright led they run about $1.40 for the wide angle single led up to about $3.75 for six leds.
I tried using uv lights in the factory locations and it didn't work. It would have had to shine directly at the gauges to do anything.
-Joe
Gots_a_sol
Postby firstgenjunkie » Fri Sep 30, 2011 3:06 am
Did you leave the interior holder stock or did you add any reflective metal tape? When I did mine I used some stuff similar to aluminum flashing tape. It is really increased the brightness. I'll shoot a pic of it this evening on the lowest setting, but it's similar to this picture of Jim Lane's truck:
firstgenjunkie
Postby Gots_a_sol » Fri Sep 30, 2011 4:32 pm
I painted it with some semi-gloss silver paint.
-Joe
Gots_a_sol
Return to Cool projects YOU can do
