HELP! no power to ignition, guages, etc. smoked and sparked
Postby Tsbourne09 » Mon Oct 24, 2011 7:41 pm
After installing my denny t pump top delete i stuck my key in the ignition and turned it over and it smoked and popped under the hood in front of the drivers seat. I did not turn the motor over just to the setting where your aux equiptment and messgage center comes on "wait to start". now it will not come on at all and will not turn over period. still have my dome light and headlights. no radio or anything else. what could it be!?
Not On Yet: 60#VS
Tsbourne09
Re: HELP! no power to ignition, guages, etc. smoked and sparked
Postby ellis93 » Mon Oct 24, 2011 8:31 pm
Did you look and see if you left something touching the grid heaters hot post. That could ground out and might burn up your fuse links on the drivers front inner fender.
Postby Tacoclaw » Tue Oct 25, 2011 4:38 am
Since you were around the IP, I'm betting the FSS wire is touching something.
Postby Tsbourne09 » Tue Oct 25, 2011 7:11 am
ok found my fss smashed in a braket but stil no start. something is fried. what could it be. also at the time i did this i had the tps unplugged. i have not put the dnr tps delete on yet not sure it tht would effect anything. also i had diesel fuel all over my fss. what could have went bad?
Not On Yet: 60#VS
Tsbourne09
Postby ahale2772 » Tue Oct 25, 2011 7:23 am
everything.... check your fuses and obvious stuff, check if the starter solinoid clicks when your try to start it
Postby Tsbourne09 » Tue Oct 25, 2011 8:01 am
checked all fuses in cab. nothing. I dont believe the started is getting power period. i hear nothing when i turn the key...
Not On Yet: 60#VS
Tsbourne09
Postby Tacoclaw » Tue Oct 25, 2011 9:07 am
Check the orange fusible link in the duckbill on the drivers side fender. That's the key-on power and should be what got fried.
Sorry, I believe it's a red wire. 2nd one in, and it's not the big one that goes to the alternator. See the bottom post of the no radio thread below this for a pic.
Postby Tsbourne09 » Tue Oct 25, 2011 9:32 am
Ok i will check that next. I rant a wire fRom positive to the fss and i herd it click then had someone get in the cab and it turned over but sparked and i let go and now yhat wont work anymore so i must have blown sumthin else now.... Good lord lol
Not On Yet: 60#VS
Tsbourne09
Postby Tacoclaw » Tue Oct 25, 2011 10:12 am
Tsbourne09 wrote: I rant a wire fRom positive to the fss
Try not to make a habit of doing things like this. By feeding power to the circuit from the wrong end, you've bypassed all the fuses that were there to protect it. After you check all your inside fuses again, cut that wire in the duckbill off, after the fusible link section, and run from the hot into it.
Postby Tsbourne09 » Tue Oct 25, 2011 11:12 am
Ok im kind of lost i pulled the link apart. Orangr wire tht connects to red/black wire and ran a wire from positive to the red/black wire.
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Tue Oct 25, 2011 11:28 am
When i run a wire from the battery to the fss it will try to start!
Not On Yet: 60#VS
Tsbourne09
Postby dazedandconfused » Tue Oct 25, 2011 12:10 pm
Run a hot wire and fusable link to the two wires that were fed by the orange wire. It's the second one from the left. If you keep back feeding threw the system you can fry the whole wiring harness is something is still grounding out. That's if we are talking about the same wires.
Postby Tacoclaw » Tue Oct 25, 2011 12:17 pm
Alright, here's a pic of the duckbill, of the two missing out of mine it's the smaller wire on the left:
And, on my 1990 W250(your truck *may* have different colors) it goes to this wire. This red wire, the one pulled out and with a knife pointing at it towards the edge, goes into the drivers side of the firewall bulkhead:
This is the battery hot that goes to your keyswitch, and looks to be your problem.
Postby Tsbourne09 » Tue Oct 25, 2011 12:57 pm
This is so frustrating. None of the orange wires run to 2 wires... I will put pics on my photobucket in a sec
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Tue Oct 25, 2011 1:03 pm
Ok my pics are on photobucket links in my signature
Not On Yet: 60#VS
Tsbourne09
Return to Electrical
