4 doors - let's build one more...
Re: 4 doors - let's build one more...
Postby draginmopars » Tue Jul 26, 2011 9:14 pm
we got side tracked bought a 93 cummins 5-speed/ 11ft. bed
it needed lots of work- brakes, tires,all u-joints,windshield,remove the tool boxes, paint
got that done..
Ramp Truck-
worked on the engine, did- KDP, took ex. manifold off to drill for the pyro
saw mismatched ports... :shock:
pulled the head and match ported the head, manifold and turbo
then decided to go 5-speed instead of auto.
Then had a tree block our driveway, took a few days to clean-up
As of now, trying to figure out
how to mount fuel tank
was in cab,Now rear frame mount
but the cross members are different heights
73 won't work, designed wrong 7"
90 is 6 1/2" tall
93 is 7 1/2" tall
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Fri Oct 14, 2011 5:58 pm
gayle has been doing some painting :D
we got the rearend and engine/5-speed back in
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Sat Oct 22, 2011 7:00 am
got the drive shafts cross members
drilled and bolted
the rear cross member
wants to share space
with the emergency brake cables and cargo bulkhead
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby ahale2772 » Mon Oct 24, 2011 5:09 am
love that magnetic drill! (im guessing its magnetic)
weve got one but it dosnt have the regular chuck style like that
Postby draginmopars » Tue Oct 25, 2011 8:47 am
ahale2772 wrote:love that magnetic drill! (im guessing its magnetic)
yes, it's magnetic- here the chuck kit #
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby ahale2772 » Tue Oct 25, 2011 12:06 pm
thanks!
ours has a center pin that kinda locates the hole.... was that the same style before you bought the chuck? the one we have uses special bits that are flat faced like an end mill, yet they have a hole down the center
Postby PToombs » Tue Oct 25, 2011 5:31 pm
Alex, that's a slugger bit. Or at least that's what we used to call them at the maintenance company.
Postby ahale2772 » Wed Oct 26, 2011 4:18 am
they work nice but sometimes they wont drill enough because they dont cut in that center section (at least on thick steel)
made drilling through the double rails on the 359 a hassle
Postby draginmopars » Thu Oct 27, 2011 7:22 pm
ahale2772 wrote:thanks!
remove set screws
un thread adapter
replace with new adapter/drill chuck
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Thu Oct 27, 2011 7:24 pm
gayle got the interior and door post painted
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Sun Oct 30, 2011 6:17 pm
fuel tank mounted
had to step the cargo floor
because of the tank
got most of the pieces cut
1" corregated alum. aircraft floor
will use the upper level
to store
the spare tire
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby Tacoclaw » Sun Oct 30, 2011 6:21 pm
I bet that's a big swing on that rotisserie. :lol: Looking good.
Alex, we use those bits specifically to drill all our big truck frames. You just got to pull them back out after each layer and let it eject the chip.
Postby ahale2772 » Tue Nov 01, 2011 5:04 am
seems like when you drill a thick piece it gums up the needle and is too much to push out....
way easier than sweatin and swearing at a regular drill tho...
sorry to hyjack :sad:
Postby draginmopars » Sun Nov 27, 2011 10:05 pm
getting ready to do the fuel lines,wiring for the rear.
First
-moved the cargo door hinges
never did like them, having to crawl over to get to things
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby draginmopars » Mon Dec 05, 2011 10:49 pm
was asked about locks for the cargo door.
used trunk locks from two Darts
the rest of the info is here ( easier to read there than transfer all the info here)
I'm lazy lol
http://ramchargercentral.com/diesel-tal ... ns-hauler/
While needing more wire for the tail light (92 diesel wasn't long enough.)
and wanting to keep the 1973 apperance, used a 73 tail panel,
need 7' , so, unpluged the haress, at the kick panel
still got more trimming and fitting to do and make a middle panel to join them together.
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
