47RH swap FINALLY
47RH swap FINALLY
Postby cmann250 » Sun Oct 09, 2011 4:31 pm
Here's what I have:
-47RH plus converter
-Adapter plate
-Starter and flexplate
All that is going into my sig truck. '89, 2wd, regular cab, 727 trans
I probably could recite the DTR stickys from memory on the subject :lol: I just want the swap to go as smooth as possible
So, what i need to know at the moment is:
Will the bolts that come out of my adapter plate still work with the 1" thicker 2nd gen plate?
Re: 47RH swap FINALLY
Postby PToombs » Sun Oct 09, 2011 5:23 pm
Yes. It's only the outer edges of the plate that are thicker. Or longer actually. You should have talked to txs, Tom, (heavyset guy with the big beard) we had a good discussion going on about turning a 727 or 518 into a lockup trans. Even I understood it! :lol:
Postby cmann250 » Sun Oct 09, 2011 5:35 pm
Yea i cought the tail end of it.
I'd look into it, but i got a screamin deal on this 47RH and all the other pieces for the swap
Postby Diesel » Sun Oct 09, 2011 6:39 pm
Not to change the subject but did I just hear that there is a way to make a 518 lockup?
1991.5 D250 Intercooled A518
Diesel
Postby cmann250 » Mon Oct 10, 2011 4:53 am
Yes viewtopic.php?f=3&t=10844
txs is the man to ask about that
Postby cmann250 » Sat Oct 15, 2011 10:07 am
Next question: What about trans cooler lines? What are my options? I know patching the existing hard lines with a hose of some sort will work, but i want to do it the right way. :;-|:
Postby cmann250 » Mon Oct 17, 2011 9:32 am
Upon further investigation, oil resistant hose isn't as evil as i thought. :roll: It will work fine for all the more i'm doing.
So all i have to find out yet is what length the driveshaft needs to be cut to. I'll measure when i get there, but just out of courisity, has any one here gone from a 2wd 727 to a 47RH in a regular cab
Thanks to everyone that's helped me get this far
Postby cmann250 » Fri Oct 28, 2011 8:00 am
Update: The 727 is out and we ran into the first problem, but it isn't major. I think. lol
The output shaft of the 47RH is splined and from what i'm told, the 2nd gen yoke just slides in and the carrier bearing and rear U-joint keep it from sliding out. The 727 appears to have the yoke bolted to the output shaft, like the yoke is on the rear differential.
Just thinking out loud here (i would like a confirmation from some one that knows more than me :lol:), if i got the 2nd gen yoke, then i'd be good. I bet i'd end up needing the whole U-joint unless Dodge was kind enough to use the same U-joint, but different yokes throughout the years.
Unfortunately for me, most people have 4x4's or 518's and there is little 2wd-727 to 2wd-47RH specific info out there :evil:
Postby txs » Fri Oct 28, 2011 8:08 am
You need the driveshaft out of second gen 2x diesel truck, illiana may have one, or you could spend big bucks and get a new one for the 1410 joint.
there are pick and pulls around indy but i have never been to one.
txs
Postby cmann250 » Fri Oct 28, 2011 8:45 am
I'll look around and see what i can find. Thanks txs
Does it have to be from a 2wd? I havent ever been under a 2nd gen to see how their transfer case hooks up. Or would a driveshaft out of a 2wd regular cab 2nd gen be the perfect length? That would be sweet :D
EDIT: it DOES have to be from a 2wd
Postby cmann250 » Sat Oct 29, 2011 7:43 am
I found a driveshaft out of a 1 ton 47RH truck that is 4x4. It is diesel. Will that work?
From what i could find, the 47RH has a 29 spline output shaft. Also i found 1 ton dodges sometimes used a transfer case that used a 29 spline output shaft. Is this true? If so my problem is solved :alien:
EDIT: The 47RH does have a 29 spline output shaft, but the transfer case of the truck i got the drive shaft out of was 32 spline
Postby cmann250 » Sun Oct 30, 2011 8:24 pm
We got the 47RH in today. I still have to wire it up, get a driveshaft made, connect cooler lines, and such. A drive shaft from a 2wd manual 2nd gen won't work, it's 23 spline.
I'm kind of talking to myself, but if this info helps some one out there, good :lol:
Postby dazedandconfused » Mon Oct 31, 2011 5:11 am
Keep it up I'm paying attention since I want to put a 47rh in mine. Is yours 2 wd?
Postby cmann250 » Mon Oct 31, 2011 4:49 pm
dazedandconfused wrote:Keep it up I'm paying attention since I want to put a 47rh in mine. Is yours 2 wd?
Yes, it's 2wd, 727. If i had 4x4 or a 518, it would go alot smoother. Either way, you should be able to modify your existing driveshaft. I have to combine two because the 727's output shaft is different than the 47RH/518 output shaft. A 518 makes it easier to modify your trans mount, the only difference in length is the 1" thicker block plate.
I hope that helps a little 8)
Postby dazedandconfused » Mon Oct 31, 2011 5:02 pm
That's what I was thinking was needed. I just want the lockup convertor to help with mileage.
Return to Transmission
