lift pump
lift pump
Postby JD91 » Tue Nov 01, 2011 7:48 pm
well my stock lift pump went out and im looking for a airdog complete fuel system. cant find one for a 91 tho :?
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Re: lift pump
Postby AHineman » Tue Nov 01, 2011 8:02 pm
http://www.puredieselpower.com/catalog/8993-dodge-59l-cummins-diesel-150gph-airdog-fuel-filterpump-system-p-25091.html
One for a 24v will work as well. I think they set fuel pressure at 10-13psi for the 1st gen kits and about 18psi for the 24 valve ones.
Re: lift pump
Postby Hansen01 » Tue Nov 01, 2011 8:12 pm
my brother has an airdog on his 02 and im pretty sure it runs 15psi, i was jus gonna get a raptor for the adjustability on the regulator
Under construction...
Hansen01
Re: lift pump
Postby JD91 » Tue Nov 01, 2011 8:19 pm
thanks for the link thats exactly what i was lookin for
JD91
Re: lift pump
Postby AHineman » Tue Nov 01, 2011 8:21 pm
No problem. 8)
Re: lift pump
Postby JD91 » Tue Nov 01, 2011 8:35 pm
did you install yourself? and if so how difficult was it??
JD91
Re: lift pump
Postby AHineman » Tue Nov 01, 2011 8:39 pm
Mines setting in the garage right this minute waiting on a nice day off of work and a Hellman sump that I just ordered today. :oops:
Re: lift pump
Postby JD91 » Tue Nov 01, 2011 8:47 pm
oh ok well i was just debating whether or not to do it myself or have it done... i just dropped my tranny last night and sent that in
JD91
Re: lift pump
Postby AHineman » Tue Nov 01, 2011 8:59 pm
The hardest part looks like dropping the tank. If you can pull your trans, I'd say the Airdog should be no problem.
Re: lift pump
Postby JD91 » Tue Nov 01, 2011 9:10 pm
cool cool well i guess ill save the money on having it done and just buy some brew and do it myself when i order it
JD91
Re: lift pump
Postby Tacoclaw » Wed Nov 02, 2011 6:34 am
JD91 wrote: buy some brew
Be careful with this, my cousin and a buddy put an Airpoodle on his 24v while drinking. By the time they got to hooking the lines up they apparently had had a little much. They hooked the return and pressure lines up wrong and said they ran the battery dead twice and filled and drained the filter about 15 times before they thought to look at the LP again. :lol:
Re: lift pump
Postby JD91 » Wed Nov 02, 2011 12:42 pm
thanks for the heads up man
JD91
