Truck wont shut off!
Re: Truck wont shut off!
Postby Tacoclaw » Mon Nov 07, 2011 2:48 pm
If you think it'll work if you move it more, just move it a spline or two in that direction. Nothing special to it from the outside.
However, since it did work before, it does sound like something internal might have moved around or something. :sad:
Have you looked at your old solenoid yet?
Postby slow_90firebird » Mon Nov 07, 2011 4:22 pm
No because I dont want to take the pump top off just to get the solenoid out. I ordered a new solenoid and also a gasket kit on ebay this morning.
slow_90firebird
Postby AHineman » Mon Nov 07, 2011 4:31 pm
You don't have to take the pump top off to get to the fss.
Postby PToombs » Mon Nov 07, 2011 5:56 pm
The 2nd wire is for the KSB. It feeds from the FSS to a sensor, then back to the KSB.
Postby slow_90firebird » Tue Nov 08, 2011 10:11 am
Ok thanks so one wire on the Fss is the ignition switched hot while the other one is a power take off for the ksb.
What is the preferred method of removing the Fss without taking the pump top off? Looks impossible to get a wrench on...
slow_90firebird
Postby ahale2772 » Tue Nov 08, 2011 10:13 am
if you have the correct wrench you can get it. not fun but it will go
Postby slow_90firebird » Tue Nov 08, 2011 10:42 am
Is this a specialty wrench I need to buy? Or will a big craftsman combo wrench fit?
slow_90firebird
Postby ahale2772 » Tue Nov 08, 2011 11:40 am
I used a hydraulic fitting double ended open style wrench, its not specific, but no, i dont think a regular combo wrench would work
Postby slow_90firebird » Tue Nov 08, 2011 4:17 pm
Ok well I played with the adjustment tonight and I was able to make the shutdown lever work without re-indexing it... I just had to completely back out the stop screw till the lever hits the pump now.
Im happy at least I have a way to kill it safely for now!
slow_90firebird
Postby Tsbourne09 » Tue Nov 08, 2011 5:21 pm
i use these to get my fss out. in and out in under a min.
http://news.thomasnet.com/fullstory/Ope ... tchet-7864
Not On Yet: 60#VS
Tsbourne09
Postby ahale2772 » Wed Nov 09, 2011 4:59 am
slow_90. make sure it shuts the truck off quick, with my pull cable I can kill the truck ssslllloooowwww but im sure its not any good for the pump
Postby slow_90firebird » Wed Nov 09, 2011 10:23 am
Yeah it shuts down quick... I was gonna get a pull cable for now but I couldn't find the one I wanted at tractor supply. Also not sure where I would put it under the dash, not much room between the brake lever and hood release, and no metal bracket on the rh side of the fuse block.
I ordered the solenoid and a VE gasket kit on eBay, might just wait and put the new solenoid in...
Anybody know what size wrench fits the solenoid? New one isn't here yet to try.
slow_90firebird
Postby Tsbourne09 » Wed Nov 09, 2011 5:35 pm
I got some thin metel cable, 2 wire clamps, a hitch pin with a handle, and a eye bolt... Less than $10 at northern tool and it worked hundreds of times! Mine is mounted above brake pedel and the right. Have pics in my photobucket
Not On Yet: 60#VS
Tsbourne09
Postby ahale2772 » Thu Nov 10, 2011 5:08 am
also, there is a bracket used for the high idle adjustment on early trucks, ive got an extra I believe, ill check when I go look at parts tonight or tomorro, its a nice little bracket that mounts up under the dash. you could use that for your pull cable bracket...or make somethign similar
Postby slow_90firebird » Thu Nov 10, 2011 10:18 am
Ok well I got the new solenoid in the mail so I just gotta get a wrench. I don't have a big enough crows foot in my set. I wanna try that and see how long it lasts for before I commit to a pull cable...
slow_90firebird
