AHineman wrote:Did you fix any boost leaks? Does it have less power or just less smoke?
AHineman wrote:You still getting full throttle travel?
Tsbourne09 wrote:Street hood stack?
Tsbourne09 wrote:Well i have seen mine as low as 14 before! But that was before the newness of the dennyt pump top and bottoned fuel screw wore off. Now its controlable. Could easily get 22ish.
Are they stock injectors?
oldestof11 wrote:Bottomed or not, the pin still has travel. Fix the leak buy drilling and tapping the AFC top with a 1/8" NPT thread tap, get some nylon line and harware from ACE. I spent around 15 for everything. I lost about 7-10psi when mine broke. I bottomed out the smoke crew but could only get 27psi maybe. Now I can peg the 30lbs gauge and slip the clutch.
