by CumminsPower59 » Tue Dec 20, 2011 5:28 am
I know for a fact that a stripped down M998 (Military Issue) Humvee will tip the scales at over 6k, and that's with the old 6.2L, soft doors and top too So, if I were a bettin' man, I would put this one over 7k as it sits. The armored versions, M1151's, eat tires like mad, we got mabe 5000 miles on a set when I was in Iraq, but there were several factors too. We had to run BFG Baja's, and Goodyear MT/R's on ours, they have a softer rubber compund, and combined with the 12000lbs of the armored variants and all the "geardo" crap the guys had on them
, tires didn't last long
. That Cummins is gonna be screaming for mercy with a TH400 behind it, the combination of the geared hubs and the ratio in the diffs put it at a good 4.30?ish to 1 ratio, the 6.2L"s and the 6.5L's we run don't like highway speeds at all. They do very well off road, using what AM General calls "brake/trottle modualtion", the goofy a$$ diffs will kinda lock up and these things can crawl over just about anything
Can't wait to see it finished Andrew, keep on with the pics!!!
