Postby Tacoclaw » Fri Jan 06, 2012 5:13 pm
Well, the truck once again proved boring and predictable...
Timing is stock and KDP is snug as a bug.
Cam bolts are at least finger tight, I didn't bother to get a socket since they don't need to come out now anyways.
And these things point at each other like they should too, so I figured it was worth capturing in a photograph. 8)
Postby m880cummins » Fri Jan 06, 2012 6:04 pm
Nice build!
I honestly think you may not need any fan at all for the cooling system. I took mine off and even on 100* days it didn't budge above 190* unless I sat at a light for 10 mins and when the water pump went out and dried the system out it hit 250* and didn't hurt a thing. In the winter I haven't seen it go above 180*
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby Tacoclaw » Fri Jan 06, 2012 6:32 pm
Thanks, man. :grin:
I do agree that the factory fan is a little overkill for a truck that does as much work as mine. (none at all) I honestly wonder if any truck with a full grill needs a fan most of the time, as I had a 95 Toyota that I ran with no fan for over 2 years.
It'll get an electric fan, since it's always good to have something just in case, but I don't think the factory one will be coming back.
Postby ahale2772 » Fri Jan 06, 2012 6:35 pm
Mine over heats when there is no movement over the radiator, so it does need a fan if you idle it at all.
Filling up yesterday, 30 degrees out, from empty to full truck heated up from 160 to 195 ish, and hit 200 as i pulled out.
within a 1/4 mile, it came back down to 170
Postby Tacoclaw » Sat Jan 07, 2012 2:31 pm
Well, I found out a local buddy carries A1 studs, and I also grabbed a set of aftercooled injector lines he had laying around. I can't wait, my next cowbell will be so big it'll block out the sun. :twisted:
Postby cmann250 » Sat Jan 07, 2012 5:05 pm
Tacoclaw wrote:I also grabbed a set of aftercooled injector lines he had laying around
May i ask what a set of IC'd lines are worth? I saw some for $150 and i thought that was pretty steep
Postby Tacoclaw » Sat Jan 07, 2012 7:22 pm
I wouldn't want to pay more than $100 for a set, but that depends on how bad you need them. I Assume they cost about $60 a pop new, so that'd be $360 for a new set.
Aftercooled lines are a different animal. They go all the way around the intake instead of crossing between valvecovers toward the middle.
Like this(not my truck):
Postby cmann250 » Sat Jan 07, 2012 7:57 pm
I see, some people use aftercooled and intercooled interchangeably. The ones you picked up look like the ones they used for bus engines
Postby Tacoclaw » Sat Jan 07, 2012 8:06 pm
I'd go a bit higher for aftercooled lines, considering how less often you see them. I couldn't look at myself if I had more tha $200 in a set though.
Postby AHineman » Sat Jan 07, 2012 8:11 pm
Tacoclaw wrote:I couldn't look at myself if I had more tha $200 in a set though.
It's hard enough to look at you as is. :P
Postby Tacoclaw » Sat Jan 07, 2012 8:26 pm
You mean you made it through that visit to your inlaws? That's too bad, I was hoping you truck would get willed to someone who would actually work on it. :P
Postby AHineman » Sat Jan 07, 2012 8:27 pm
Tyler doesn't need it, no room for a car seat. :lol:
Postby Tacoclaw » Sat Jan 07, 2012 8:31 pm
Pffft, he won't work on his truck. That 4 door has been sitting since the baby.
Postby Tacoclaw » Sun Jan 08, 2012 5:51 pm
Behold the fury of Microsoft paint:
The plan is just what you see. Running a 3" (maybe a squished 4") hole at the back of the intake, then Y in another pipe that goes to the factory grid heater at the front. I'm looking for a 3" guillotine to run towards the back inlet, so I can close it when it's really cold and just pull through the grids. My truck is still a little grouchy when it's real cold and it's not plugged is, so the grids are needed if ether isn't available.
I am debating on whether to lean the rear inlet so it points towards the back of the head or if just it's location will be enough.
Postby ahale2772 » Mon Jan 09, 2012 8:38 am
shooting the inlet twards the #6 runner would not hurt.
