The Mustard Bucket
Re: The Mustard Bucket
Postby dazedandconfused » Sat Jan 07, 2012 7:39 pm
What size tires are on the back in that pic? Did you move the leaf springs to the inside of the frame rails?
Postby ellis93 » Sat Jan 07, 2012 7:43 pm
That's one cool looking truck man!!!! ;)
Postby SuperiorRam » Sat Jan 07, 2012 9:45 pm
dazedandconfused wrote:What size tires are on the back in that pic? Did you move the leaf springs to the inside of the frame rails?
31-18.50-15 on weld drag lites 8" back space Dana 60 cut down to accept b body Mopar axles and the leafs are under the frame now
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Postby SuperiorRam » Sat Jan 07, 2012 9:50 pm
Thanks for the compliments y'all :alien:
SuperiorRam
Postby dazedandconfused » Sun Jan 08, 2012 12:37 pm
Have any pics of the rearend setup? I've seen them moved to the inside of the frame rails never under though.
Postby SuperiorRam » Sun Jan 08, 2012 1:53 pm
Have I gotten your gears turning Andy?
I'll put it on the lift here and snap a few
Heres another vid
http://i160.photobucket.com/albums/t181 ... 39dcc0.mp4
SuperiorRam
Postby dazedandconfused » Sun Jan 08, 2012 2:07 pm
:mrgreen: Yeah especially sice I'm so traction limited. I was thinking about moving them to the inside of the frame. Don't really want to do 4 link but it's an option.
Postby SuperiorRam » Sun Jan 08, 2012 4:02 pm
I cut and modded the factory mounts the problem with in he frame is the two crossmembers are right where the spring bolts go I also removed the two bottom springs
http://i160.photobucket.com/albums/t181 ... 5d8ecc.mp4
SuperiorRam
Postby dazedandconfused » Sun Jan 08, 2012 4:15 pm
So are you down to just the main spring now. I hate that this phone won't open photobucket videos. I'd like to tuck 33" tires back there.
Postby SuperiorRam » Sun Jan 08, 2012 9:26 pm
Want me to text you vids pm yer number there is three springs
SuperiorRam
Postby dazedandconfused » Mon Jan 09, 2012 6:01 am
Gotcha mine must have already had some leaves removed then since it only has 3. You have a pm.
Postby SuperiorRam » Sat Jan 14, 2012 3:20 pm
Got the 4200 spring and 7x.012 sticks in and holy crap fifty pounds of boost and roasting tires its a blast!
SuperiorRam
Postby oldestof11 » Sat Jan 14, 2012 6:31 pm
Dude! Cool truck! If it were me though, the angle of the stack would be just a tad higher than the bed line. Awesome!
Postby SuperiorRam » Sat Jan 14, 2012 11:02 pm
SuperiorRam
Postby dazedandconfused » Mon Jan 16, 2012 8:37 am
So have you been able to get it to hook without blowing the tires off yet? Whos injectors are you running? I have a buddy that gave me a 5 lug D60 I'm thinking of throwing a spool in and putting under mine. I was going to cut down the 3.07 D70 but may just do the D60 to save some coin.
Users browsing this forum: No registered users and 127 guests
