Am I right or dumb?
Re: Am I right or dumb?
Postby Mark Nixon » Wed Jan 11, 2012 7:50 am
PToombs wrote:I see Levi keeps up the Begle love drama also, I thought I was the only one that remembered "dirty" Sanchez! :lol:
I, too have noted some of Begle's "conquest stories" and recall the Sanchez incidents well. ;)
As far as the 351 turbo(s) spoken of here, the HE351CW is the mechanically wastegated turbo used on '04.5 through '07 5.9s and will bolt directly to a VE 12 valve's exhaust manifold.
It has a 9cm housing and may EGT higher on a long, hard pull, but it's a nice working turbo that clears the air pretty well down low.
The HE351VE is a variable vane turbo, which would be a splendid all-around turbo on the 1st gen, if you can get it to work right without spending a fortune on a controller.
It'll also function as an exhaust brake, but has the downside of an oddball T-flange pattern that requires an adapter on the pre-2007.5 engines.
