Postby oldestof11 » Sat Jan 21, 2012 5:19 pm
210 cfm stock... upgradeable to 310 in the future. No stock head is going to give those numbers. :twisted:
Postby ahale2772 » Mon Jan 23, 2012 2:46 pm
if i had the cash, that's what I would drop it on, even tho I'm already under fueled as is.
Why not go all out?????????????
Postby oldestof11 » Mon Jan 23, 2012 3:04 pm
If he bought the head, I think that S475 would spool like a stock 21cm H1C. :twisted:
Postby Tacoclaw » Mon Jan 23, 2012 6:04 pm
You bastards. :grin:
Just to spite you I'm getting my stock head fixed and putting it back on. Seriously, a local cat informed me that our valveseats are integral to the head and aren't able to fall out(Where were you guys at on that one? :P ), so I'm getting a valve job done for $130 and running it. I'll save for a Hamilton, but it'll take a lot of info gathering before I drop the cash on one.
Postby ahale2772 » Mon Jan 23, 2012 6:15 pm
I was going to call u out on that, i guess if it was SERIOUSLY cracked it could fall off... :lol:
Only another excuse to buy the hamilton head...
Postby JustinRhodes » Mon Jan 23, 2012 7:15 pm
Tacoclaw wrote:You bastards. :grin:
Id be worried about more than the head on your truck if you have been talking to a local cat. :lol:
JustinRhodes
Postby Tacoclaw » Mon Jan 23, 2012 8:18 pm
Pretty funny, now get back to stroking your Pee pump. :lol:
Postby JustinRhodes » Mon Jan 23, 2012 8:23 pm
Tacoclaw wrote:Pretty funny, now get back to stroking your Pee pump. :lol:
I never stopped? I can multitask :)
JustinRhodes
Postby diesel freak01 » Tue Jan 24, 2012 6:25 am
LEVI JUST DO THE @!#$%!@# HEAD ALREADY. Ok I think im done for a while. But seriously do the head while you have the chance so you dont have to spend the money twice. You have already said she is down til spring so why not just do it the right way once instead of cobbling and then taking it back apart to do it right! :grin: :cheers:
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Tacoclaw » Tue Jan 24, 2012 11:59 am
Current prices for Hamilton Cam's head as of 1/23/12:
Head with only oversize valves: $2900
Loaded head with beehive spring and titanium retainers: $3400.
Sorry guys, you'll have to live vicariously through someone else with this head, it's just not worth it for me right now. If it was closer to $2k I would have swung it but triple the price of a Cummins head just isn't worth it for my application...
I'll still squirrel away some cash for it, but it'll be a few years at least and probably longer as I'm needing to get a posi and start on some body work. :yuck:
Postby BC847 » Tue Jan 24, 2012 3:54 pm
Tacoclaw wrote:Did you end up with a cam, BC? Be careful, they'll ruin your engine before you even put them in. :lol:
Finally got up with Zach today. Naturally, they sold the last wide-lobe 12v 188/220 . . . two hours before I called. Won't have anymore until February. :roll:
So being a repeat customer running a bunch of his mess, he cut me a deal on a steel 188/220 (no bushings required) and 24v lifters. 8) I've already got his 110 springs and pushrods. I expect it'll be a bump up from the 181 I'm running. :twisted:
Our heads have always had integral seats. It's covered well in the FSM:
Postby ahale2772 » Tue Jan 24, 2012 4:22 pm
A steel 188? KEWL 8)
Zach is a great guy to deal with. I'd like to run his pushrods at some point, I can't see how the difference in the 24v pushrod socket VS the 12v is any good, so I'll use that as an excuse to but them
Postby Tacoclaw » Tue Jan 24, 2012 4:33 pm
ahale2772 wrote:A steel 188? KEWL 8)
http://www.competitiondiesel.com/forums ... p?t=127428
Posted about a week after my cam arrived. :roll: Not that I need one, but still. :cry:
Postby ahale2772 » Tue Jan 24, 2012 4:36 pm
:oops:
I havnt been on CompD in a while, not around a computer as much these days....or should I say when I am on the computer, compD is not where I need to be
Postby BC847 » Tue Jan 24, 2012 4:39 pm
I had not seen that. Yeah, he cut me a VERY good deal compared to that. :shock:
ahale2772 wrote:Zach is a great guy to deal with. I'd like to run his pushrods at some point, I can't see how the difference in the 24v pushrod socket VS the 12v is any good, so I'll use that as an excuse to but them
The 24v lifters are wider than our stock items. As such, they match the wider lobes of the new cam. The idea is to better support the loads running todays lube oils (low/no sulfur).
