dual 5" stacks
dual 5" stacks
Postby 92 D/UNIT » Sat Jan 06, 2007 7:32 pm
has anybody ever had or have any photos of a 1st gen with stacks? been thinking about putting some on but not sure what they would look like.
388/886
92 D/UNIT
Postby g1625s » Sun Jan 07, 2007 9:14 am
I've got one :wink:
adding non-protected photo :oops:
presently-'96 4x4 2500
formerly-'89 W350
g1625s
Postby Greenleaf » Sun Jan 07, 2007 5:12 pm
My 92 has twin 5" miter cuts, centered in the bed (close together) and terminate at the top of the rear window glass. A lot of work but can be accomplished. It's easier to set them in the bed corners, but then again, everybody does that.
Greenleaf
tech specialist/mod
Postby 92 D/UNIT » Mon Jan 08, 2007 7:14 pm
do you have any pics? do you have a chamber or are you running y pipe? also hows the sound? just recently put a 4" down pipe on and ran the exh. out just past the cab(temperarely not sure were im gonna go from there yet) sounded like crap, and i like loud exh. had to put a muff on. im hoping that stacks sound a lot better.
388/886
92 D/UNIT
Postby Greenleaf » Tue Jan 09, 2007 3:37 am
I have several pics. PM me your e-mail and I'll send you a few.
Greenleaf
tech specialist/mod
Postby Greenleaf » Thu Jan 11, 2007 5:19 am
Brian,
I don't have a Y pipe. The stacks are centered/close together, and therefor won't work. I build a Boot T. It's in the shape of a cowboy boot. Lots of cutting/welding. It would be much easier to use a box and set the stacks on that in the front corner of the bed.
The sound is horriffic. I had to install a performance muffler. I beleive it's due to the very short stacks and it's all pipe. No box. The box style I have built in the past are much quieter.
Greenleaf
tech specialist/mod
