# 5 injector
# 5 injector
Postby remi » Thu Mar 08, 2012 9:36 am
what is the best way to fix aleaking injector
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: # 5 injector
Postby cmann250 » Thu Mar 08, 2012 9:48 am
What exactly is leaking? Got a pic?
Re: # 5 injector
Postby PToombs » Thu Mar 08, 2012 6:04 pm
Usually if it's the hold down nut, just snug it a little. Fuel leaks, loosen and retighten. That works most of the time.
Re: # 5 injector
Postby remi » Thu Mar 08, 2012 7:23 pm
k thanks and right where the block and the nut enter each other
remi
Re: # 5 injector
Postby PToombs » Fri Mar 09, 2012 6:27 pm
Just snug it up. If that doesn't work you have 2 options, remove hte injector and replace the copper seal washer, or you can heat the old washer red hot and drop it in a bucket of water and reinstall it.
Re: # 5 injector
Postby remi » Tue Mar 13, 2012 9:12 am
ok with the truck in my sig what would be the best set of injectors to put the stock ones
remi
Re: # 5 injector
Postby PToombs » Tue Mar 13, 2012 5:13 pm
Need to know what you are doing with the truck, drag race, drag trailers, sled pull, daily driver, looking for MPG or what. Makes a huge difference with all the different injectors out there.
Re: # 5 injector
Postby remi » Wed Mar 14, 2012 10:47 pm
pulling trailers and dd maybe a sled hook every now and then
remi
Re: # 5 injector
Postby Dieselwrencher » Thu Mar 15, 2012 11:15 am
Most of the time when we see a leaking injector and the leak isn't from the return and feed line, it is the holder nut leaking at the body. Fuel will leak in the injector bore and make a mess.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
