Low-compression pistons on the street?
Postby Begle1 » Sun Oct 28, 2007 5:04 pm
It's pretty impossible to run the 15.3 ratio pistons without having lots of blue smoke all the time, right?
Has anybody ever ran them on a daily driver?
Postby KTA » Sun Oct 28, 2007 8:06 pm
Depends on your timing injectors and outside air temps. I have several 15.3 motor in daily drivers running around that don't smoke at all once warmed up. 8)
Postby ford69557ci » Tue Oct 30, 2007 10:00 am
i hope the .060 head gasket i am goin to be runnin doesnt drop the compression to much. whats factory 17.5-1 18-1????
ford69557ci
Postby dpuckett » Tue Oct 30, 2007 4:38 pm
Factory compression is 17.5:1. How thick is the stock H.G? I have the .020 over, and it starts fine if I let the grids warm up.
I'd think if you had the right injectors, timing, and air flow, you wouldnt smoke much, cold or warm. Lot of N14s are in the 14.5-16:1 range.
Heck, a 6.9 IDI with a 22:1 compression will smoke if the fuel system isnt up to snuff.
Daniel
Postby ford69557ci » Tue Oct 30, 2007 5:14 pm
yeah my nieghbors 6.9 idi looks like its on fire till it warms up for about an hour
ford69557ci
Postby KTA » Wed Oct 31, 2007 6:51 am
A 0.060" gasket is about stock thickness.
Postby 92 D/UNIT » Wed Oct 31, 2007 6:29 pm
ford69557ci wrote:yeah my nieghbors 6.9 idi looks like its on fire till it warms up for about an hour
now thats funny!
388/886
92 D/UNIT
Postby Begle1 » Thu Nov 08, 2007 7:49 pm
Should I expect a mileage drop with them?
What about starting troubles?
Postby GPSMatt » Thu Nov 08, 2007 9:16 pm
is it a bad idea to fly cut the stock ones? what's a good source for low comp pistons
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Sun Nov 11, 2007 1:34 am
any input on my above post anybody?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby GPSMatt » Sun Nov 11, 2007 3:38 am
just found a post kta did in another section that the marine ones are15:3(?) and that they have a bigger bowl. What good does the bigger bowl do? well it burn more fuel better
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby therabbittree » Mon Nov 12, 2007 8:50 pm
I have a set of marine pistons I've been saving to use in a build..I've been nervous about trying them, as I snowplow and drive my truck alot in real cold weather..not sure how they would be in 0 degree temps..any one know?
Thanks
Deo
therabbittree
Postby KTA » Mon Nov 12, 2007 9:40 pm
They would be fine with a good load, but not without. They also would not build as nuch heat. I would save them for more of a toy and leave the high comp pistons for snow plowing.
Postby GPSMatt » Tue Nov 13, 2007 3:07 am
anyone have a source for marine pistons URl?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby KTA » Tue Nov 13, 2007 8:43 am
I get my marine pistons from cummins. 8)
Users browsing this forum: No registered users and 72 guests
