Re: Back to Progress (never ending)
Postby CUMMINSDODGEMAN3 » Tue Mar 27, 2012 11:38 am
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby tampabayBill » Tue Mar 27, 2012 11:48 am
Been checking in on your build thread often and wonder what you are using for fans. Trucks looking real good !
Twins coming soon!
tampabayBill
Postby ivel_86 » Tue Mar 27, 2012 11:58 am
Tacoclaw wrote:Thanks for the comments, guys.
I feel kind of bad, because there's not even close to a day and a half's worth of info in this thread. :lol:
Well I got lots of time being were I am at... And its an extremly interesting thread. I am enjoying it very much!
US ARMY SGT
OIF 08-09
'93 W250, 4in Sky Lacker 35in Kelly Safari, Pump turned up, Fuel Pin ground, Pyro and Boost gauges, Straight piped, Home made air cleaner assembly.
ivel_86
Postby Tacoclaw » Tue Mar 27, 2012 1:12 pm
As embarrassing as this is, we've got one of those gensets sitting outside right now that I did some work on. I didn't even pay attention to the color... :oops:
Roosa pump, 6bta with the water "a"...
Think they'd notice if that aftercooled got replaced with my old non-IC'd intake plate?
I'll check on the fans when I get home. I can only hide in this generator so long before a boss catches me. :mrgreen:
Postby CUMMINSDODGEMAN3 » Tue Mar 27, 2012 1:37 pm
lol well atleast scrape that emblem off before you leave it! i got probably a box full of those
CUMMINSDODGEMAN3
Postby diesel freak01 » Tue Mar 27, 2012 1:48 pm
If your dad calls me again today ill make sure to mention to look at the generator!!!
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Tacoclaw » Tue Mar 27, 2012 5:47 pm
He can't call Cat anymore, he said his wallet couldn't take it. :P
I fired it up tonight!! Rockauto came through like a monster and had my steering hose here in one day. Bleeding the fuel turned out to be a huge PITA, which turned out to be because I didn't tighten any of the air ferrels on the suction side of my LP. The 2 on the filter were easy to find, but the one on the LP I didn't notice until after I had dropped the tank again to check my pickup. :oops:
It fired up nice, and besides a couple of return leaks it didn't have any drips. There's still a return leak at the tank I'll have to fix and once I rerun the valve it'll be ready for a idle up to temp and then another retorque of the studs and the valves again.
Of course the damn thing blew smoke all over me when it started. I think it smokes worse now than it did before, so who knows how bad that fuel line restriction was hurting me...
Oh, and if it's not a big deal, I'll get the fan info tomorrow. I spent the night laying in a pool of diesel so I'm gonna hit the shower and the recliner.
Postby JustinRhodes » Tue Mar 27, 2012 10:10 pm
Tacoclaw wrote:He can't call Cat anymore, he said his wallet couldn't take it. :P
Let me know how much $ that line is!
JustinRhodes
Postby diesel freak01 » Wed Mar 28, 2012 4:03 am
His wallet must not hurt too bad as he wants me to price him a Certified on that 980C. :shock:
Glad you got that thing running. Hopefully i can get mine back on the road before i forget it completely.
diesel freak01
Postby Tacoclaw » Wed Mar 28, 2012 4:26 am
That was the first 980 they ever bought new, he's still in love with it.
See if you guys can throw an F cab on it at least. No fm radio sucks when your stuck in there all day and the only other thing you have to listen to is truck drivers. :lol:
Postby Tacoclaw » Thu Mar 29, 2012 7:04 pm
Just got back in from buttoning everything back up(as far as I know). I got the grill on about 4 hours ago and swore that I would drive it to work tomorrow, no matter what. Every time I would get ready to pull it out, I would remember some little thing I needed to do. You know, bleed the brakes, tighten the lugnuts, little stuff like that.
I finally do a couple laps around it, can't think of anything else, so I jump in it to pull it out into the fresh air. Turns out my clutch rusted together from being steamed-cleaned. I couldn't get it loose, and didn't have anyone to push the clutch while I beat around on it to try.
I feel terrible for my 1st gear synchros... :lol:
Postby AHineman » Thu Mar 29, 2012 7:12 pm
That's what you get for actually trying to clean things up and paint them. :lol:
Postby Tacoclaw » Thu Mar 29, 2012 7:17 pm
I know, right?
I thought about trying to run it outside on the starter and getting buck wild on it to break it free, but I'll just wait until tomorrow. I don't have enough beer to start an operation like that right now anyways.
Postby PToombs » Fri Mar 30, 2012 6:00 pm
Start it, let it get warm. Shut it off, put it in 1st. Start truck. Drive with the clutch in until it pops loose. Just whomp on it a few times in different gears, it'll loosen up. ;)
Postby JustinRhodes » Fri Mar 30, 2012 7:53 pm
Let me know if you need a hand tomorrow. I wont be up to anything important
JustinRhodes
