Different Kind of Hybrid Turbo!!!!
Postby mhuppertz » Mon Nov 12, 2007 9:10 pm
DynaCharger
"Turbodyne Technologies Inc. is a leading engineering company in the design and development of charging technology to enhance the performance of internal combustion engines."
The Turbodyne Dynacharger is an electric assist device that can be adapted to specific turbochargers. The Dynacharger system comprises an electronically controlled ultra high-speed brushless electric motor that's mounted between the turbine and the compressor of a conventional turbocharger, together with an electronic power and speed control system.
Electrically, the operation of the Dynacharger alternates between Motor Mode and Generator Mode. In Motor Mode, the Dynacharger provides the desired boost pressure for low speed engine acceleration. In Generator Mode, the Dynacharger utilizes the otherwise wasted surplus exhaust gas energy by using the turbine to drive the electric rotor. At full engine power, the generator can be used to slow the turbine, and in many cases alleviates the need for a wastegate.
The most obvious benefits are improved transient response, boost pressure available at low rpm and low load and greater turbo sizing flexibility - you can rely on the Dynacharger for low-end boost and you can opt for a huge compressor for strong top-end performance.
See the Dynacharger at www.turbodyne.com
mhuppertz
Check this out
Postby mhuppertz » Mon Nov 12, 2007 9:31 pm
mhuppertz
Postby ford69557ci » Tue Nov 13, 2007 11:53 am
looks like somethin someone would try and pawn off on ebay
ford69557ci
Postby GPSMatt » Tue Nov 13, 2007 12:41 pm
wow that is kinda gay so seems like it would be way more efficient to just do it the standard issue way of turbo charging using hte exhaust gas's that prolly puts a lot of draw on the alternator as well
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby mhuppertz » Tue Nov 13, 2007 12:47 pm
Dyson's not gay, he's English!
Just kidding. I put that "Half-Bakery" thing up there because that site cracks me up!
Mark
mhuppertz
Postby GPSMatt » Tue Nov 13, 2007 12:49 pm
the dyson thing is funny i was talking the electric turbo
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby mhuppertz » Tue Nov 13, 2007 1:48 pm
GPSMatt wrote:the dyson thing is funny i was talking the electric turbo
The one that I think does have potential is the hybrid electric turbo. Electrically spooling your turbo at idle and having boost at the ready would not only be really fun, but also increase mileage quite a bit and nearly eliminate smoke.
mhuppertz
Postby ford69557ci » Tue Nov 13, 2007 5:50 pm
use nitrous it will spool the turbo clear up smoke and its probably a hell of alot cheaper
ford69557ci
Postby mhuppertz » Tue Nov 13, 2007 6:34 pm
ford69557ci wrote:use nitrous it will spool the turbo clear up smoke and its probably a hell of alot cheaper
Point taken!
mhuppertz
Postby DTanklage » Tue Nov 13, 2007 10:35 pm
not at 2.50 per pound
DTanklage
Postby GPSMatt » Wed Nov 14, 2007 2:35 am
wonder what that unit costs.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Wed Nov 14, 2007 8:46 am
i dont know, but at 2.50/pound, and the capiblility to use one pound in a few seconds, it is still cheaper in the long run
DTanklage
Postby ford69557ci » Wed Nov 14, 2007 5:26 pm
until the warranty runs out and the brushless motor or controller burns up then u have to buy another one. just tune you afc right and chose the right size turbo.
ford69557ci
Postby DTanklage » Wed Nov 14, 2007 7:18 pm
"just tune your afc right"
is that the same as removing the lever?
hehe
DTanklage
Postby ford69557ci » Thu Nov 15, 2007 7:58 pm
well for me it is but fore the people that are going the gayle banks way they dont want the smoke
ford69557ci
Users browsing this forum: No registered users and 68 guests
