cougar wrote:If you are having trouble with your brake lights and turn signal lights, I'd check the multifunction (aka turn signal) switch. Your brakes go through that switch so the same element in the bulb can be used for both. Had that happen on my 91.
redneckroot wrote:Or it could be a short in the trailer wiring if you have trailer wiring. I've had more then one truck come through including my own with a bunch of light problems that didn't make and sense that ended up being a short in the trailer wiring. My 2nd gen I had shorted out inside the trailer plug.
dazedandconfused wrote:Your multi function switch is bad thats why the flasher button messed up everything. Have you checked the fuses and fusable links. I replaced a fusable link that powers the blower and wait to start lightd. If that fuse blows when I turn on the blower those will light up.
