Electrical Woes... Tail light and turn signals
Postby peobryant » Thu Mar 22, 2012 2:06 pm
Well, I'm having some more problems with my truck. My turn signals and tail lights don't work. I've replaced all 4 bulbs in the rear, replaced the fuse that was labeled as "stop lights" and still nothing. When I turn my parking lights or headlights on, the rears light up, but when I press the pedal they don't. What could be the problem? I'm not much of an electrical man (as most of you know) so it may be something simply I'm overlooking.
Also, as I was replacing the fuse last night I apparently didn't put the fuse box back up correctly and when I was driving the work my boot knocked the box back down. I reached down to put it back up and heard a pop and sparks started flying. I assume the metal part of the fuse box hit my steering column or something, but now my windows won't roll down. Every time I hit the window switch all the lights on the message center light up and I don't hear the motor running. I'm assuming it's just a blown fuse, but before I go back to the auto parts store I figured I'd run it by you guys.
Thanks for any help.
Re: Electrical Woes... Tail light and turn signals
Postby PToombs » Thu Mar 22, 2012 4:58 pm
Parker, you have a bad ground on the rear lights, someplace. Lesson for the day,
When lights flash or are on that shouldn't be, or when something comes on and another light goes off, it's usually a bad ground. ;)
Use a test light on the fuse box to see where there is power and not. You may have popped a fuseable link under the hood. This is just a guess, as I don't have power windows and have never blown a link.
Good luck buddy!
Postby Hansen01 » Thu Mar 22, 2012 5:45 pm
X2 on the ground, exact same thing happend to me. trace the grounds from each side of the tailights
Under construction...
Hansen01
Postby peobryant » Fri Mar 23, 2012 2:08 pm
Oh joy...
Thanks for the help, I'll post back later with results.
Postby PToombs » Fri Mar 23, 2012 5:29 pm
You better!
Postby redneckroot » Fri Mar 23, 2012 7:23 pm
Or it could be a short in the trailer wiring if you have trailer wiring. I've had more then one truck come through including my own with a bunch of light problems that didn't make and sense that ended up being a short in the trailer wiring. My 2nd gen I had shorted out inside the trailer plug.
redneckroot
Postby kbhblazer » Sat Apr 14, 2012 12:24 pm
Could be the light switch itself, that was my problem, I came off before the switch and anded a toggle switch for the park lights. it helps unload some of the curcuit because the wiring on the trucks os way underengineered
kbhblazer
Postby cougar » Sun Apr 15, 2012 8:12 am
If you are having trouble with your brake lights and turn signal lights, I'd check the multifunction (aka turn signal) switch. Your brakes go through that switch so the same element in the bulb can be used for both. Had that happen on my 91.
01 2500 "the work truck".
cougar
Postby welderboy250 » Sun Apr 15, 2012 8:22 am
cougar wrote:If you are having trouble with your brake lights and turn signal lights, I'd check the multifunction (aka turn signal) switch. Your brakes go through that switch so the same element in the bulb can be used for both. Had that happen on my 91.
2x on that. I've seen that deal many times.
welderboy250
Postby bmoeller » Sun Apr 15, 2012 7:08 pm
As Pete said, grounds would be good to check. It's free. ;) But, I'd lean towards the multi-function switch myself. Been there, done that.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Hansen01 » Mon Apr 16, 2012 5:19 am
redneckroot wrote:Or it could be a short in the trailer wiring if you have trailer wiring. I've had more then one truck come through including my own with a bunch of light problems that didn't make and sense that ended up being a short in the trailer wiring. My 2nd gen I had shorted out inside the trailer plug.
This is also a good place not to forget, this still happens to me once in a while if dirt or something gets in there
Hansen01
Postby peobryant » Tue Apr 17, 2012 12:28 pm
Haven't had much of a chance to look at my truck, but I did figure out how to get my taillights and blinkers working again. Unfortunately it hasn't answered anymore of my questions but instead has left me more confused than before.
My hazard lights haven't worked in a few years and I figured it was just a fuse but I couldn't be bother to fix it. Fast forward to my little problem in the first post, as I was driving along I noticed the hazard switch was in the "on" position, and when I pushed it back down my blinkers and taillights worked again. So, why the hell did that happen, and what do I do to fix it the proper way?
Also, after my idiotic mishap with the fuse box, not only do my windows not roll down, when I turn on my heater or A/C all the lights on the dash light up and the blower seems to be on, but not doing much of anything whereas before it was pretty strong.
Did I mention I hate electrical systems and wiring? :mad:
Thanks for the help guys.
Postby dazedandconfused » Tue Apr 17, 2012 1:28 pm
Your multi function switch is bad thats why the flasher button messed up everything. Have you checked the fuses and fusable links. I replaced a fusable link that powers the blower and wait to start lightd. If that fuse blows when I turn on the blower those will light up.
Postby peobryant » Tue Apr 17, 2012 2:30 pm
dazedandconfused wrote:Your multi function switch is bad thats why the flasher button messed up everything. Have you checked the fuses and fusable links. I replaced a fusable link that powers the blower and wait to start lightd. If that fuse blows when I turn on the blower those will light up.
I've checked fuses and those seemed to be alright but I'm not even sure what the fusable links are, or how to check them. Like I said, I'm a complete novice when it comes to wiring and electrical systems so I need all the help I can get.
And where is the multifunction switch located? This is the first time I've heard about it. It's not the same thing as the headlight switch, correct?
Thanks again.
Postby dazedandconfused » Tue Apr 17, 2012 2:40 pm
No its the turn signal, wiper, dimmer, flasher switch. Its all one piece under the steering column covers. Under the hood in the wiring you will see black fat spots in the wires. Those are your fusible links and Mark has said when they burn out you can stretch them. I stick a multi meter gauge on each side and check for 12V's.
Return to Electrical
