Junkyard Volvos=Gear Vender?
Postby Rug_Trucker » Wed Apr 18, 2012 6:59 am
Do I need to start checking Volvo's for a Gear Vender OD? Are there parts to adapt them to our trucks? And will they handle the power?
Gracias! :lol:
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Re: Junkyard Volvos=Gear Vender?
Postby CumminsPower59 » Wed Apr 18, 2012 8:17 am
I, personnaly have never heard much bad about gear vendors, they claim to handle alot of power. My brother runs one on his 02, really likes it. ;)
Postby BILTIT » Wed Apr 18, 2012 10:55 am
There are 2 types of gearvendors units, a P type and a J type.
I cannot remember which one is which but when i talked to GV they said the Volvo units will not hold up to towing.
Derek B.
BILTIT
Postby Mark Nixon » Thu Apr 19, 2012 7:32 am
I dunno' but here lately, I've seen a lot of GV stuff for sale that "needs repair" or something's broken or missing.
From what I understand, it's like pulling teeth to get GV to even do something about fixing them.
Been that way for years.
IMO, if a company won't sell parts, or support their product, they deserve to go belly up.
Postby CumminsPower59 » Thu Apr 19, 2012 7:58 am
The unit my brother has on his 02, we got used, the control box was bad, but the actual over drive unit was good. All it needs to shift is 12 volts. So I wired up its own relay, on/off power and push/pull actuation switch and it works great. Got less than $1k in it :mrgreen:
Postby BILTIT » Thu Apr 19, 2012 10:36 am
I bought a used unit that basically had nothing with it. I purchased all the parts needed from GV and didn't have any issues. They support parts no problem, not sure about repairs though.
Derek B.
BILTIT
Postby oldestof11 » Thu Apr 19, 2012 2:27 pm
You have to send it in to be repaired.
Postby Diesel » Sun Apr 22, 2012 7:20 pm
Where does the GV mount? AFter the trans? Will it work to give an auto even higher gears on the hwy?
1991.5 D250 Intercooled A518
Diesel
Postby BILTIT » Sun Apr 22, 2012 7:45 pm
If its 2wd it mounts to the back of the trans, 4wd on the back of the t-case. There is a divorced mounting option aswell. Yes it gives a greater OD to autos aswell.
Derek B.
BILTIT
Postby PToombs » Mon Apr 23, 2012 4:27 pm
That looks like a lotta extra weight hanging off the back! :shock:
Postby BILTIT » Mon Apr 23, 2012 4:33 pm
Its actually not very heavy. ~40lbs
If you think about it, the whole t-case (200lbs?) is hanging off the back of the trans itself.
Derek B.
BILTIT
Postby PToombs » Tue Apr 24, 2012 5:35 pm
That's true about the TC, but it's fairly close to the mount. The GV sticks way out. 40 lbs isn't much though.
Return to Transmission
