Stuffed it full of RTV, wrapped it with some foil, and rewrapped it with the fireplace door sealer stuff. Anything to keep from having to take it down.
Tacoclaw wrote:Oh, and here's a pic of my new boost controller setup:
It's an adjustable pressure switch from Napa and a 12v spool valve. I just turn the switch to wherever I want and it opens the valve and dumps the boost to the external 'gate. I don't even have the internal 'gate hooked up anymore. It seems to be working great, as boost comes up fast and when it gets to where I set it it stops right then.
I do intend to relocate it and clean everything up, but I wanted to get some testing in with it before I went through all the trouble.
napa has them..here are some of the part numbers...701-1603,701-1605,701-1575,701-1576,701-1608,701-1609,701-1577,701-1578,701-1604,701-1606 nd dual circuit p/n's 701-1591,701-1592, nd 701-1607....you can go on napa online to check the psi nd factory set point...just remember if you do..just type in "bk" before every part number..or just go into your local napa store with these part numbers nd someone should be compitant enough to help you
